Question about HP LaserJet 4100 Printer
Refurb HP Laserjet 4100. When we use OEM cartridges we get a repeating image, but this does NOT happen with a refilled cartridge. Suggestions?
    Scholar:
  • 118 Answers
turn on/off, unplug, wait a minute, plug back in, should reset.
take all paper out. check to see if any paper is jammed in the rollers
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order.
lastly, check make of printer trouble shooting web site for more information. hp has an awesome site for trouble shooting printing issues
hope this helps, good luck.
Posted on Apr 29, 2010
Hp cm 6040f half tone calibration error
Reset the NVRAM, HP support and google the procedure.Also, may be physical defect from the printer:
- ITB
- Fuser
- All cartridges
The only other parts involved with imaging would be the laser itself, or some kind of power problem where the laser isnt getting charged enough. You could try plugging it into a different wall outlet without a surge protector to confirm power source problems.
The imaging drums should all be included in the toner cartridges. They should have been ruled out when you swapped them before, its also unlikely all 4 drums would go bad at the same time.
Also, are you using refills or OEM cartridges? It shouldn't matter but refills/refurbs can have some strange defects. If you have a spare teh same model of printer lying around you could swap the cartridges out from a working machine and see if the problem travels with the cartridges or not.
Regards, Mike
Oct 20, 2015 | HP Color LaserJet CM6040f MFP Q3939A...
How to fix hp 4100tn very light printing
Try a new cartridge first if you have not done that. Keep in mind that many third party, refilled or reman cartridges do not produce the same toner density as OEM HP cartridges. If a different cartridge does not produce better results then you either have an issue with the transfer roller, power supply or dirt on the laser scanner lens. If the inside of the printer is relatively clean you can rule out the scanner lens in most cases. 9 times out of 10 it is cartridge problem.
Sep 09, 2014 | HP LaserJet 4100 Parallel Monochrome Laser...
Supply memory error color
A "supply memory" error is usually caused by a bad toner cartridge. Each cartridge has a chip that is read by the printer.
Try reseating the cartridges.
Did the error occur after you swapped out a cartridge?
Jan 13, 2014 | Hewlett Packard Printing & Imaging Refurb....
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
Not printing magenta
Have you tried another printer cartridge? If you're refilling or using refilled cartridges, you may have a bad cartridge or the roller that holds the laser image is damaged.
The other possibility is there are problems with the toner cartridge contacts. Remove the cartridge and clean the contacts and cartridge with a clean dry cloth.
Jun 01, 2012 | HP Color LaserJet 2600n Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
My printer won't print---I just had the black ink cartridege refilled but it keeps saying replace supplies
Return the cartridge and use only genuine supplies with HP. HP cartridges have chips on them that dictate if they are OEM or not. Typically, if you use a refiller , these chips won't get reset.
Oct 20, 2010 | HP LaserJet 2840 Printer
Refilling of Laserjet Cartridge
dear sir good morning
sir please send a soulation for refilling of hp laserjet 1020 prineter cartridge with graphic soluation. request send immeditely in my E-Mail ID
shaan_rao@rediffmail.com
May 15, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
How to refill HP Laserjet C4127x Cartridge
http://base0.net/archives/207-Refilling-Laser-Printer-Cartridges.html
http://www.wisegeek.com/how-do-i-refill-toner-cartridges.htm
Jan 09, 2008 | HP LaserJet 4050n Printer
HP Laserjet 1022
Have you refilled the toner cartridge or is it refill as when these toner cartridges are refilled they have a tendency to leak. I suggest to remove toner cartridge turn the machine off vacuum out the inside and replace the toner cartridge with a new original. Run 20-30 prints through to get rid of any other loose toner and then should be fine.
If printing doesn't improve then repeat process if still same problem suggest transfer roller to be changed.
Hope this helps
Thanks J
Nov 15, 2007 | HP LaserJet 1022n Printer
HP LaserJet 4100 Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
