Question about Whirlpool GS460 Gas Kitchen Range
Constant beep and displays F1E1 - Whirlpool GS460 Gas Kitchen Range
My frigidaire side by side model#GLHS37EHSB7 is making a constant beeping noise and the electronic temperature display isnt coming on. what could be causing this
Hi Julie, this is JK. Thank you for your recent post!
I see that your Frigidaire Refrigerator, GLHS37EHSB7, is constantly beeping but the electronic temperature display is not working. Generally, this could happen when you experience a power failure. I would strongly suggest that you either unplug or turn the circuit breaker off to the unit for about 30 minutes. Let the unit reset completely and try to use it as normal again. If this concern still continues, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Hope this helps!
Mar 19, 2014 | Frigidaire Refrigerators
Constant beep no display
Try drying the board with a hair dryer but not so hot to destroy the electronics. Place an ample amount of distance between the board and the electronics. Set aside for an hour, then try the machine.
Jan 14, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
F1E1 error on my whirlpool oven. What does this
F1-E1 Defective ERC Replace ERC
ERC= electronic oven control
Jun 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Constant beeping when powered up, no display
If the beeping is constant, check your keyboard for any keys that are stuck in the depressed position.
Jul 07, 2009 | Computers & Internet
I have a fault on my oven F1E1
This it the proper solution for your problem:
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Mar 30, 2009 | Stoves Ovens
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
Constant beeping and F7 is displayed
Hi tahitian,
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Dec 16, 2008 | Magic Chef 31000 Gas Kitchen Range
Whirlpool GS460 Gas Kitchen Range Logo
59 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
