Have problem with the following: Ricoh AF 2035/2045 error code 670/672 Ricoh AF 2075 error code 670/672 Ricoh AF 2075 error code 990 What is the problem with the machines. We have changed the board but still not working
  • copystar May 03, 2010
    Wat kinda solution is this?
Mix-it-up
  • 832 Answers
SOURCE: Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Posted on Oct 23, 2007
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
SOURCE: Ricoh AF-2020 SD problem
how can i get drivers fore this printer
Posted on Sep 08, 2008
pierre1811
  • 144 Answers
SOURCE: E6 error code displayed on Kenwood kdw243a dishwasher
The reset sequence used is:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
Posted on Jan 19, 2009
M2Tech1
  • 313 Answers
SOURCE: error code SC998 on Ricoh Aficio 1045
The error code 998 is usually for the dimm or application boards read errors try taking the memory out and the app board out and reseat them again.. then go into the service mode via yellow clear button and then enter 107 then hold down the stop button till the panel changes and turn off the copier wait for 5 secs then turn back on.. If you dont know where boards are take the back panel off and on the right hand side there is a box with a steel plate on the dimms Ram..and app boards are there.. Good Luck A..
Posted on Jul 30, 2009
Error code sc 650
Ricoh AF 3025 error code SC650 is wat problem?
Jan 03, 2012 | Ricoh Aficio 3025 All-In-One Laser Printer
IN RICOH AF 2045 SC 990
This error code could be related to a Physical problem (machine) or Network Problem.
Physical problem:
Try to clean the ID sensor.
Probably you will also need to clean or replace the Drum Unit.
Network problem:
Upgrade your firmware.
(If you do not have technical skills a advise you to call your provider)
See you!
Jun 06, 2011 | Ricoh Aficio 2035 Copier
I need aficio af 2020 software and driver to download
To download the driver for Ricoh Aficio 2020 follow these .steps :
1. Go to the link below
Driver download for Ricoh Aficio 2020
2. Select your operating system from the given list.
3. Download the required driver software.
Nov 17, 2010 | Ricoh Aficio 2020 All-In-One Laser Printer
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Dec 28, 2009 | Ricoh Aficio 1035 Copier
SC 400
Hello sir; The error code you post out, it's means "transfer belt bias problem" that you have go to high voltage board ,I/O board or main board, before we go, why don't try make a reset;
1, press "clear mode" key, then enter 107 then press and hold down "clear/stop"..
2, turn power off and on.
Jan 11, 2009 | Ricoh Aficio 450 Copier
Ricoh af 220
Hello sir; that's laser motor problem, we can reset it, the procedure as follow;
1, press "clear modes" key .
2, enter"107".
3, hold down "clear/stop" key until SP modes come up.
4, turn off power and on again (main power switch)
If doesn't work , then you have to replace motor.
Jan 08, 2009 | Sharp AR-M205 Copier
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
77 people viewed this question
k24674
jasbo
jasbo
