Question about HP Photosmart C6180 All-In-One InkJet Printer
Creased paper when printing from InDesign
When printing any document from Adobe InDesign CS3 to my HP C6180 print, the paper creases about 1.5 inch down and will not print file. :(
I have no idea what to do and can't find any information anywhere on internet.
  • 4,041 Answers
Hello there.
You may not see a paper jam.
It is worth a try.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 29, 2010
The printed page comes out creased from the top left of the page to the bottom right.
Download this manual >> http://www.mediafire.com/?i0y9iqnqu79ppcj Go to page #203(6-15) Paper Feeding problems (wrinkles or creases) and follow the troubleshooting steps.
Note: PDF manuals require the Adobe Acrobat Reader for viewing and printing. http://get.adobe.com/reader/
Sep 03, 2011 | Brother HL 5140 Laser Printer
Paper comes out creased on one side
If the printed image is smudged, as well as creased, you might have a torn Fuser fixing film.
You will need a technician to fix that.
If it is just a crease, just check that
1. Your paper is not damp. Try a fresh packet of paper
2. The paper input tray guides are set to the width of the apaer, to prevent the paper skewing as it feeds.
Good luck.
Jun 21, 2010 | HP LaserJet 1012 Printer
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
I can't print full bleed from CS3 to a Phaser 7750DN
You didn't mention paper size, so my apologies if you are using a sheet that will accommodate bleeds and just didn't mention it. This is the simple answer.
If you printing on 8.5 x 11 paper, you can't get a full bleed. You'll need to print on a larger paper size, like tabloid, and trim your 8.5 x 11 size out of that. There are no printers, even commercial offset printers, that can bleed an 8.5 x 11 design on an 8.5 x 11 sheet. There must be trim in order to get the bleed. it 'bleeds' off the edges of the design.
Nov 11, 2008 | Xerox Phaser 7750DN Laser Printer
Can't print from Indesign CS3 to Epson stylus photo 2100
It sounds like a buffer overun problem. Try reducing the resolution of your graphics. Have you contacted Adobe? You have one year free technical support with the software, I believe.
Jun 19, 2008 | Adobe Photoshop 7.0 for PC
Printing from Indesign CS3 to Epson CX11NF problem
hi-
Actually what i can suggest is that for you to try printing from a different application, such as microsoft word or paint. try printng a landscape image. now if its going to print it correctly call adobe since that might be an application issue. thanks for using fixya!!
May 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
Ricoh 1013f Paper creasing
1- you need to determine at what point it's creasing
a) when leaving the tray
b) when getting to drum
c) when exiting copier
2- after that you need to see what the problem is,
a) small paper that was torn off causing problem,
b) is the part worn
c) something out of place
3- remove paper or replace part
Nov 12, 2007 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
