Question about Whirlpool Accubake RF362LXTS Electric Kitchen Range
Whirlpool range - power surge, loss of power neutral to my service. The electronics on the top of the stove does not work. The burners work. Can it be repaired economically or should I consider a new range?
    President:
  • 2,468 Answers
The part is about $140.00 and depending if you attempt the install or someone else does the install will dictate price total depending on your areas labor rates please rate this
Posted on Apr 29, 2010
My whirlpool SF265LXTS oven turns on properly, but the oven itself isn't getting hot. The gas stove top and broiler both work fine.
It sounds like you might have a clogged burner plate or manifold. You should call a certified gas repair service. This could be very dangerous, even deadly.
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
My whirlpool electric stove a burner don't work l
my whirlpool electric stove top two big buner is not working
Nov 28, 2012 | Kitchen Ranges
Whirlpool electric range super capacity 465 RF 377PXGQ0 SER# RH 4718582 the stove burners work nothing else works the control panel and oven are not working at all no lights at all... everything...
Ok
you must have a problem with you neutral leg .
Check to mak sure all 3 wires from power cord are securely connected to machine. Next make sure recepticle at the wall
has a good neutral. Use volt meter to check your recepticle.
You should get 110 volts between any top and the bottom slot.
No 110 volts means check house wiring or recepticle
Yes 110 volts means problem with neutral wiring in machine.(Not likely)
good luck
Jul 26, 2011 | Ovens
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
We have a Hotpoint RB787 Electric Kitchen Range. We experienced electrical issues/ power surge and now the oven part of the stove does not work. top still works and only indicators for the top burners...
you will need to replace the control board that contains the clock readout,any power surges ruins these electronics instantly,this can be replaced by removing the rear cover on the back of the unit and remove screws securing the electronic module
Jan 08, 2010 | Hotpoint RB787 Electric Kitchen Range
After a recent power interruption the Electronic
These electronic controls are very sensitive to power surges. I am afraid your control is now bad and must be replaced.
There are no fuses or reset buttons.
Nov 13, 2009 | Magic Chef 31000 Gas Kitchen Range
Blank Display on Electronic Oven Control
If the burners are working it is not the circuit breaker as both use the same circuit. The board does use the ground or neutral wire. I would check that and see if there is 12VAC supplied to the board. If there is then it would appear you have a fried board.
Eric
Jun 27, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
PF on Whirlpool super capacity 465 electric Stove Model RF366PXGW2
PF = Power Failure. Sounds like you have a bad electrical connection. With your breaker off, check that the connections from the cord to the range are all good and tight. Next, check the receptacle where the cord plugs in. Remove the cover and check the connections there as well. Examine the power cord also. There could even be a poor connection at the breaker box (at the circuit breaker or the neutral buss bar) but not as likely, as your problem appeared when you moved your range.
Oct 19, 2008 | Whirlpool RF378LXKS Electric Kitchen Range
Whirlpool Accubake RF362LXTS Electric Kitchen Range Logo
226 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
