Question about Bosch Washing Machines
Smells grey sludge on clothes
Smells -grey sludge on clothes -tried machine cleaners- boil wash etc
    President:
  • 2,468 Answers
Its from all the old detergents not getting to the drain and lay in the outer wash tub,the smell is from mold starting to form in this gooey mess,you may need to remove the inner tub to get this goo out of the outer tub,then make sure the drain pump,hoses are also clean of this goop and there are no kinks,or blockages in the drain hoses or pump
Posted on Apr 29, 2010
BOSCH MAXX WFO 2062
Have you checked the outlet pipe that the machines pipe discharges into ? Sometimes these get filled up with sludge etc and may siphon back in smelly water at the end of a cycle. You could also see where the pipe drains into the sewer system , see if there is a local blockage.
Jan 08, 2014 | Washing Machines
My LG intellowasher wd8015c is very smelly. I have run clr though it as instructed for washing machines but it still smells. I do have a user manual...HELP!!
To clean your LG, Whirlpool, Samsung, Frigidaire, GE or any other clothes washer try Smelly Washer Cleaner! It's 24 treatments of all natural washing machine cleaner that also safely and easily will remove mold and mildew odor from towels and clothing! To compare with other washer cleaners go to: http://www.youtube.com/watch?v=Ua6OJPn0-fU
Dec 14, 2010 | LG WM1812C Front Load Washer
Is there a filter on the wmt 03 hotpoint washing machine
We have the same machine which had the same problem, there is no filter only a colection pot at the bottom of the machine. Unfortunately even cleaning this did not solve ours, in the end I had to strip the machine down, split the drum down and then flush the brown crud which had accumulated behind the steel inner drum. Ta da problem solved!. Probably not what you'd want to do if you were not confident in attempting it but it saves buying a new machine.
Sep 09, 2009 | Washing Machines
Bad smell inside drum and when draining also makes laundry smell
Recommend running it through empty (and without soap) on a long, hot wash cycle a couple of times.
Modern cool cycles don't always wash away all the detergent, and the machine fills up with smelly grey sludge after a while.
A.
Aug 01, 2009 | LG Washing Machines
Grey sludge on my washing
Hi, I had the same problem.
The waste is blocked, check the drain pipe from the machine and also where it drains out to. (thick sludge)
I ended up unclipping the pipe from the drain motor (Bottom rear) and passing a garden hose throught it to flush it out.
Jan 07, 2009 | Zanussi FJ1254W Front Load Washer
Hi, I have a Baumatic Washing Machine (not sure of the model) and cannot find the filter. The machine gives off an awful smell which I am trying to fix
you should find the filter but that is not what is causing the smell. common causes of smell are:
using liquid detergent - this smells like drains if used for a long period and leaves a horrid sludge in the tub. put on a boil wash with no clothers and use powder detergent
plumbed in under the sink and there is also a waste disposal unit. these pong!
no water barrier between the drain of the washer and the house drains
Jul 10, 2008 | Baumatic Washing Machines
Scum on my clothes espically whites help
you need to do more washs on 90 but dont put bleach in its just sludge build up between the drums vey normal ffrom doing warm washs all the time i do 95 degree washs evey three months to keep machine clean.hope this helps.
Mar 26, 2008 | Zanussi FJ1454W Front Load Washer
Whirlpool duet washing machine
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
405 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
