Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer does not heat
How do i gain acsess to fuses
    Problem Solver:
  • 9 Answers
My model is LEQ2152EE1 and the thermal fuse is at the back and you take off the top to get too it.
Posted on May 02, 2010
Where is the thermal fuse located on ge DPSE810EGWT
It is located the topr right side on the heating element housing. You will need to remove the drum to gain access to it.
Jan 05, 2014 | GE 5.8 Cu. Ft. Extra-Large Capacity...
I have a fisher & Paykel electric dryer. D-DE62T27D that works but won't dry. Any solutions? Thanks Rick
Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Dryer heating elements come in various shapes and sizes. They are all strung with a coiled wire made of a nickel and a chrome alloy. This wire receives, but resists, a controlled electric current and as a result, the wire heats up. The heat produced is used to heat and dry the clothes in your dryer.
Once you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it.
Jul 12, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Dryer want heat up what's problem
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it. Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Dryer heating elements come in various shapes and sizes. They are all strung with a coiled wire made of a nickel and a chrome alloy. This wire receives, but resists, a controlled electric current and as a result, the wire heats up. The heat produced is used to heat and dry the clothes in your dryerOnce you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it, thanks to parts direct
May 31, 2011 | Maytag Neptune MDE6800 Electric Dryer
Dryer functions but no heat; only cool air
unplug dryer and gain axcess to back of dryer and remove back wall plate look at lint shute bulkhead housing their will be one thermostat with four wires and one white plastic fuse safely remove the wires off fuse and tape together for testing only ...... make sure cover with electrical tape now make sure wires dont touch anything meatal no plug in dryer and check for heat if dryer starts heating goahead and order new fuse and replace thermal fuse ,,, and clean dryer venting and check for any kinks in vent pipe ........ if that test didnt produce any heat replace heating element its in aluminum duct on right side of the back of dryer ...... their is also a high limit tstat on the upper left side of this duct you can jump this out for testing only and check for heat aswell donot operate dryer with these jumped out except for testing theses are safety precautionary thermostats,,,
Jan 28, 2011 | Whirlpool LER4634J Electric Dryer
Everything is connected properly and the dryer wont turn on
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Dec 31, 2010 | Dryers
I have a kenmore elite model # 110.6706. It is making noise like a bearing is going out. I took the back cover off but can't see where the noise is coming from. What is the best way to gain acsess to the...
from the front, it sounds like the dryers drum support rollers may be bad, here is a website that will explain the replacement. Good Luck Tim:
http://www.partselect.com/dryer+replace-rollers+repair.htm
Oct 21, 2010 | Kenmore 63942 Dryer
The dryer will not start but the timer is working
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again.
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor.
May 21, 2010 | Whirlpool LER4634J Electric Dryer
I have an LG DLE2532W dryer. It suddenly stopped putting out heat. I've heard that there's a heat regulator switch that can trip if the unit overheats located underneath the barrel. What's the easiest...
You r correct. Take top off. Take control unit off. Take front off. Search how to videos online, YouTube, repairclinic.com, appliancepartspros.com
Jun 05, 2017 | LG DLE2532W Electric Dryer
Thermal fuse or heating element problems on a medt236ayw maytag
Normally you will remove the back of the machine and locate the air tube that goes from the blower to the drum...the thermostats and heating element are normally located there.
Sep 26, 2009 | Maytag MDE4806 Electric Dryer
Not getting hot
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 13, 2009 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
279 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
