Question about Rosen G8 CV8090 Car DVD Player
Won't come on
My player won't come on and the light want come on. does anyone know where the fuse is i think that it is blown
    New Friend:
Monitor not coming on also will not accept dvd
Posted on Apr 25, 2011
Check the fuse boxunder the hood. Use a standerd auto light tester. If there is light its good.
Posted on Apr 04, 2008
SOURCE:
I have a 2000 Vauxhall Astra Estate and the fuse for the radio has blown but I don't know which fuse it is. Does anyone know which it is?
is the cigarette lighter working if so it may be the one on the radio its self. can blow the radio fuse and not the main fuse. radio fuse is less think it is 5amp as main fuse can be 15-20amp fuse.
Jan 02, 2013 | Vauxhall Cars & Trucks
SAMSUNG SP-50L7HX DEAD FUSE BLOWN BLACK OBVIOUS SHORT CIRCUIT ANYONE KNOW ANYTHING IF BOARD REPAIRABLE O
Try shopjimmy.com who carries almost all the Samsung boards--if fuse right where power cord does come in trouble is right there.
Aug 30, 2012 | Samsung Televison & Video
My sony kds 60a2020 won't come on. When I push the
That is a error code and in several of these sets it means thermal fuse is blown--Google the model number with owner manual or service manual to learn for sure.
Jun 07, 2012 | Sony Televison & Video
Vw polo abs light won't go off. I've replaced the 40 amp strip fuse located in the fuse comparment above the battery but it still hasn't gone off even thought the orginal fuse was blown. Anyone...
Well, first of all, did you fix the problem that caused the fuse to blow? Have you scanned you Antilock Brake System (ABS) module for fault codes? Since the computer is the one responsible for turning the light on, wouldn't you think that the computer would be the one to ask WHY it has turned the light on?
Please also review the following articles:
Where's The Fuse?
What Else Could Be Wrong?
Sep 11, 2011 | 2002 Volkswagen Golf
I HAVE PAYED $20 TO GET SOME HELP WITH MY DASH LIGHTS NOT WORKING. ALSO MY PARKING LIGHTS WON;T COME ON. ALSO MY FOG LIGHTS WON;T COME ON. I HAVE ASK YOU SEVERAL TIMES TO HELP ME. IT MAKES ME THINK. YOU...
Sorry about that, I must have missed your post or something. The park lights and the panel lights are usually on the same fuse and therefore on the same switch. The fog lamps are on a separate fuse and switch/circuit, although the is nothing to prevent either of the fuses going at the same time. Look at the fuses first, if they are blown replace them, but if they blow again some more investigation will be required. The parking lamps/panel lights are unlikely to have a relay, but the fog lights may.
The fuse must be in the main fuse box. The position and function of the fuses is normally marked on the inside of the fuse box cover and also in the owner's handbook. If you don't come right with these, work your way through the fuses looking for a blown one. To ease your search the fuses you are looking for should be around 15 to 20 amps.
Mar 06, 2011 | Jeep Grand Cherokee Cars & Trucks
I have a 2000 Ford Excursion. The fuses for my tail lights, and console lights are blown. Blinkers and brake lights work fine. Does anyone know which fuse numbers I need to give attention to? Thanks.
I ve been tying to write this but had site problems. I am thinking you might have a short in your tow package pigtail .This happens quite often Good luck
Jan 17, 2011 | 2000 Ford Excursion
Blown fuse, i think
pull one fuse at a time check to see if its blown,continue until you find the blown one(hold fuses to a light to see if the wire in fuse is seperated.)
Jun 11, 2009 | Sport & Outdoor - Others
Kenwood head unit not powering up help please.
find your remote wire. it would help to know the type of car and the kind colors of wires your using as your 3 main wires.
normally in most chevy and fords they are yellow 12 volt.
black as ground.
red sometimes even a tan as your remote start.
deff check your start
May 09, 2009 | Kenwood KDC-W6027 CD Player
Open Questions:
See all Rosen G8 CV8090 Car DVD Player Questions
Rosen G8 CV8090 Car DVD Player Logo
360 people viewed this question
Top Rosen Car Audio & Video Experts
Pierre Laplante
rd2xpld
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
