Question about Kenmore Elite HE3 Steam 8674 Dryer
I meant is there a reset sequence? H3 Model # 110-8482-1300
Tip
Xerox XC and XD series copier H3 or H4 error code reset procedure
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
on Mar 20, 2010 | Office Equipment & Supplies
Getting H3 error message Sharp AL 1631 copier
H3 is a heater/fuser problem. Try to reset it by SIM 14. Press Clear , auto exposure, Clear and auto exposure and press copy key. check if H3 has been reset and LED is back to "00".
Oct 29, 2009 | Sharp AL 1631 Copier
The sunroof on my 2009 Hummer H3 leaks.
What they meant by "they all leak" is that the sunroof seals around the glass are not meant to keep water from getting down in the sunroof, and tray and drains are there to drain the water that does get down in there. The problem most likely exists with your drainage tubes. They can either be clogged, or in my case with my 06 H3, the tubes were somehow disconnected and I had to drop down the roof panel to reconnect one.
Jul 08, 2009 | 2009 Hummer H3
Sharp AR-405 showing error H3-01... how do I reset this error?
press the following in sequence
program / interrupt /clear /interrupt
press 14 and enter
restart and away you go.
let me know if it works
Jun 22, 2009 | Sharp AR-M205 Copier
H3-00 fault
H3 - 00. This means High Temperature in the heater section, proberbly caused by a faulty thermistor.
Firstly try a reset, please press the following buttons IN SEQUENCE:-
Program - Interrupt - Clear - Interrupt - 1 - 4 - Print.
If this cures the fault, your good to go, if not you'll need to replace the part.
thank you
Jun 02, 2009 | Office Equipment & Supplies
Sharp AL-1631 overheats after replacement of fuser and fans
Hello sir; that's a simple problem whayever you mention all the parts you replace are not necessary, if you can't reset H4,or H3 then you need to replace "THERMISTOR" that is the device to control the temperature, the parts #RDTCT0128FCZZ.
Feb 12, 2009 | Sharp AL 1631 Copier
XEROX WORKCENTRE XE80 DISPLAYS AN H3 CODE
Try this procedure.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time
Jul 17, 2008 | Xerox Office Equipment & Supplies
Error code H3 displayed on Xerox XC1044 Copier
this is the solution:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode' (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the 'Print' button, then the second part of the code followed by the 'Print' button again.
To exit diagnostics: Press 'Clear' repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select '14' followed by 'Print'... exit diagnostics.
H3 stands for high temperature at the fuser.
Mar 15, 2008 | Computers & Internet
Kenmore Elite HE3 Steam 8674 Dryer Logo
77 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
