Question about Kenmore 62622 Microwave Oven
Microwave works but not heating up, not even lukewarm 1000 watts
  • djkreyol Sep 01, 2008
    hi every time i turn on he works with a loud sound and not heating if some body can help me fix it please , is model number :66029/66022 kenmore
  • Anonymous Sep 09, 2008
    my microwave popped while running and quit heating food, however everything else still works
  • Kenmore Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If not, please reply back with your brand and full model.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
I have a brand new Avanti 1000 watt microwave. (New, out of the box). It won't heat. It makes noise like it's working, but there is no heat generated.
Take the lid off and on the side were all the components are located you could see a large transformer mounted on the bottom look at where the wires get plugged in one may not be in and hanging lose or the fuse in a white like casing come from transformer to the capacitor is blown
Oct 03, 2013 | Avanti MO902SST 1000 Watts Microwave Oven
Everything works except the Microwave. Even when you start the Microwave the table turns etc but no heat. Was making a buzzing noise then burning smell.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 14, 2011 | GE JVM1790 1000 Watts Convection /...
THE MICROWAVE WILL NOT HEAT
The microwave uses a magnetron to heat. They can go bad. It is the most common problem with a microwave that works but doesn't heat. partselect,com has the part, the diagrams and pics, and everything else you will need to change your magnetron
Dec 28, 2010 | GE JVM1850 1000 Watts Microwave Oven
MMV4184A 1000 Watts Microwave Oven: My microwave turns on but does not heat the food. ...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fsjf
May 18, 2010 | Maytag MMV4184A 1000 Watts Microwave Oven
Microwave wont heat food. Everything else works.
Micorwave doesn't work when the megatron tube is out. That's probably why it won't heat up. Either replace microwave or the tube. You can get the number from Sears for the megatron tube by calling customer support.
Nov 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
Aug 29, 2009 | GE JVM1850 1000 Watts Microwave Oven
Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Mar 04, 2009 | Whirlpool MH1150XMQ Microwave Oven
Microwave hums
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Runs but won't heat
Does the turn table and interior light come on?
Nov 25, 2008 | GE JVM1870 Microwave Oven
Kenmore 62622 Microwave Oven Logo
89 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
