Question about Dishwashers
Not filling up with water it is a hotpoint aquarius df61
    Habit-Forming:
  • 193 Answers
Check in let valves
Posted on Apr 29, 2010
2 Suggested Answers
  • 120 Answers
SOURCE: aquarius df61 fill problems
check the float on the inside of the machine. if it is stuck up, the machine assumes it is full of water and will not allow any more to enter. it looks like little cone or hat and should move freely up and down. if that is okay, it has to be the water inlet valve. good luck
Posted on Nov 04, 2009
My hotpoint aquarius df61 do not clean properly cannot find the problem all filters cleaned .all of the crockery comes out dirty
Just had same problem. Checked and cleaned spray arms filter and impellor. Still had problem. Noticed that it appeared to be expeling water to drain at wrong time. Openned mid cycle and noticed water level low.
Took off left side panel to reveal pipework. Main pipe route big oblong in clear plastic had a red valve at the top which was gunged. This was the air release so when water is pumped in air has nowhere to go so it pushes water out through the waste so ther is too little water in machine. Removed this component and used caustic soda to dissolve food waste blocking valve as there is no access. Put it back together and now it works fine. Took about 2 hours (1 hour for caustic to work) no special tools other than star screwdriver required as it all unclips.
Nov 14, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius drum fills to top with water
will it stop when you stop the cycle? if so your pressure switch could be the problem however if that does not stop the water you intake water valve is most likley the problem
Feb 06, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius df61 fill problems. My dishwasher does not fill with water on either the wash or the rince cycle. How can this be fixed
Oct 25, 2009 | Dishwashers
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius DF61 Dishwasher & Food residue remaining
i have cleaned the filter on my hotpoint aquarius DF61 on cant put it back together.
Nov 17, 2008 | Dishwashers
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Salt tray full of water
Just pour a bag of dishwasher salt in water will come out.Then light goes out.
Jul 25, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Dishwashers Logo
445 people viewed this question
Top Dishwashers Experts
