Question about Whirlpool RF378 Electric Kitchen Range
Accubake electric smooth top range
I started the oven on self clean and it gave me a e1 f-5 error message, now it will not turn on, just beeps at me. What should I do??????
  • Anonymous Apr 10, 2008
    I have the same problem when trying to clean my oven (whirlpool acubake) I get this F5E1 error. Everytime I try to clean it, it beeps with error message. Not sure what to do?
  • Anonymous Nov 28, 2008
    What does an f2 code mean? whirlpool
    Guru:
  • 93 Answers
You more than likely have an issue with the door lock assembly or the temp sensor probe. Not sure off the top of my head the the exact codes are. A model number to the appliance can help us get that. Machine is worth repairing just hang in there!!
Posted on Mar 25, 2008
Frigidaire smooth top electric range flashes f9 after cleaning
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
What is the model number?
Nov 28, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My Whirlpool Accubake super capacity 465 self-cleaning oven does not work. When started E1 -F5- appears on screen. Model# RF 386 PXGO. Serial# RJ0525903.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%#FDG
Jan 02, 2010 | Whirlpool Accubake RF362LXTT Electric...
Oven wont come on
Cleaned the oven yesterday with self clean and the next day while cooking on the top it just stopped working
Dec 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F3EO error message
Replace the oven temperature sensor.
Mar 16, 2009 | Whirlpool Accubake RF362LXTS Electric...
Door will not unlock after self clean.
It's probably the timer motor which is stuck. unplug the range!! I recently had the same problem with my whirlpool (hereinafter known as **** inc.) range. Self cleaned the oven and then the door wouldn't open. Googled up similar problems and generally found out that ****inc. had this problem on both gas and electric ranges and it costs an arm and a leg for a new board plus labor. Found out how to manually open door with coat hanger but of course still had problem with same error messages; also the oven, clock, etc wouldn't function. Took the cover off the back of the stove. UNPLUG THE STOVE On the left rear facing the back of the range he found the timer motor had stopped.He unplugged input(230 volt power) leading to the stove, then unplugged and insulated the wiring to the timer motor and the microswitch on top of it ( 4 wires). Then he took the long steel wire off of it and unlatched the oven door. Told me that this probably had something to do with the timer motor on the self cleaning cycle and that it was stuck Said this whole thing could probably be fixed with a bit of WD40. Said probably nothing wrong with board but it sure must be a moneymaker for **** inc. The service techs probably clean the timer motor, say they changed the $300 board, and go on their way. Plugged stove back up and voila! Everything worked except self cleaning function. Hope this helps someone. caution!!!! Do NOT use the self cleaning function unless you fix the timer motor. Replace it or clean it.
Nov 21, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Accubake - Can't get out of clean mode
cannot get out of clean mode, although the oven outside is cool, but door is locked and display still says cleaning, door locked and time of 3 hrs 15 min is displayed. NOW WHAT?
Nov 16, 2008 | Kitchen Ranges
Whirlpool RF378 Electric Kitchen Range Logo
231 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
