Question about Whirlpool GSW9800PW Washer
I think i need a new lid switch. how do i remove
I think i need a new lid switch. how do i remove the front casing to access?
3 Suggested Answers
  • 130 Answers
SOURCE: need to replace lid switch
what brand machine? whirlpool take off the cabinet and the switch is on the rhs under the lip
Posted on Jan 30, 2009
  • 212 Answers
SOURCE: how to replace lid switch
you should either have screw at both sides on rear of control panel. if not you have tension clamps at right and left side at bottom of control panel in front. use putty knife. flip control panel back. undo lid switch harness. lift lid up and pull lid switch out. remove 5/16 ground screw first
Posted on Jun 24, 2009
How is the lid switched changed? What is the
Remove the Cabinet and replace the switch,unplug washing machine first.take off the two screws from the console carefully flip it over. remove the lidswitch connector. then remove the 2 brass brackets. slowly pull the whole case towards you. note how the front bottom goes under the washer base. ---------- The detailed procedure is as follows:--- This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
---------------------- This will help.Thanks.Helpmech.
Feb 21, 2011 | Kenmore 25842 Top Load Washer
GE WJSE3110AOWW Motor will not opperate, cycle works, pump works, fill works,
The lid switch mechanism on these is pretty tricky. They use a combo of old fashioned levers in conjunction with a switch. Sometimes the strike will not hot the tab on the switch mechanism or the metal will fatigue on these292db5e.jpg and cause problem, later models use a magnetic switch these days. To access the switch mechanism you needs ta remove the front panel first. Place a putty knife about wher the tub edge is on both sides and push the front panel down and towards you. Once you get that out the way you can then remove the top and gain access to that pesky lid switch13aead2.jpg
Training Manual
That's my solution. What do you think?
Mar 21, 2010 | Washing Machines
Instructions on how to replace lid switch on Whirlpool Washer, model # LSQ911OPW2
The following link explains how to replace the lid switch on a Whirlpool top loader:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
The part number (if you haven't purchased a replacement yet) is 3949247. If you have questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Sep 11, 2009 | Washing Machines
I think lid switch needs to be replaced
It could very well be the lid switch. Or, in the case of your washer, it could be the actuator that controls the switch, or the lid strike on the lid itself. Appliancepartspros.com has some excellent exploded view diagrams that you can refer to. Type in your model number (the last character is a zero "0", not and O) and the lid switch components will be listed under the "Top and Cabinet" heading in the following manner:
Item 10 - Lid Switch Shield
Item 11 - Lid Switch
Item 12 - Lid Switch Acuator
Item 20 - Lid Strike
Any one of these components could have been damaged so you will need to inspect them all.
The exterior washer case has to be removed in order to view these components. Follow these steps:
The lid switch and associated components are located on the right hand side. Refer to the parts drawings on the website I referenced to assist in part location. It's a pretty easy repair job. All you should have to disconnect is a couple of electrical connections, a ground wire and mounting screws.
If you have questions, or need additional assistance, please let me know. I hope you find this information helpful.
PS All parts combined, cost less than $30. Not bad for a Do-It-Yourself repair.
Aug 26, 2009 | Washing Machines
Estate Washer will not drain (model: SM 8280867) appears to have a damaged sensor on the lid, need info on how to access this piece, also need info on how to access the pump if this is not the problem
If this is an Estate top loader, check your lid switch. Since the pump is mechanically driven, it usually is not the problem unless it is clogged. The washer will still run, though, if this were the case. This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: Some washer models have the lid switch located near either the left or right hinge of the lid. This type of switch is activated by a rod on the hinge pin. If not functioning, it can often be adjusted by bending the hinge rod until it engages the switch.
You can access the drain pump by removing the washer case. The pump is located directly in the front of the washer under the wash tub. It has two hoses attached. All you have to do is remove one of the drain hoses to drain any water. However, before you do that try using a wet dry shop vac on the drain hose by pulling it from the standpipe at the wall and pulling a vacuum on it. This will minimize the need to mop up any water. These wash tubs have a capacity of about 35 gallons. That's a lot of water to bail or try to mop up. If the water drains with a vacuum on the line, the pump probably isn't clogged. NOTE: If the lid switch is defective, you do not have to drain the tub to install a new one. The water will drain once the switch is repaired.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
PS Are you sure you have the model number correct? I tried doing a search on that number and it doesn't cross to anything. I think you may have posted the Serial Number. Please verify and post back with a correct Model Number if this is the case. I would like to be able to confirm how your washer is configured.
Jul 19, 2009 | Washing Machines
My 70 series kenmore washer won't spin . I think it is my lid switch, how do I remove it to replace it?
To replace a lid switch on a Kenmore top loader, just follow these steps: First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps: 1. Under the console you will find the lid switch connector. Unplug the switch from the connector. 2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release. 3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first. You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge. Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps: 1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips. 2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in. 3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget. A replacement lid switch can be purchased on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. All these sites offer great service and competitive pricing, so shop around for the best price. Use your complete model number (located along the tub rim under the washer lid) for your search criteria. If you have questions along the way, please let me know. I hope this helps you.
Jun 09, 2009 | Kenmore 25852 Top Load Washer
Kenmore, cloths washer, lid switch replac. Wiring harness access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Kenmore Washing Machines
Roper Washer model RAX4232KQ0 won't fill with water
Jan 02, 2009 | Washing Machines
Kenmore elite top loaded washer has problem that indicates Lid
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
I need to replace the dryer belt
The belt on a dryer is inside the body, usually accessed and changed as follows
most base dryers
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
maytag
  • remove screws from bottom bend of front panel
  • lift front panel off
  • remove doo switch cable
  • sent front panel aside
  1. drum motor felts and bearings are now accessible.
  2. lift drum and withdraw fully forwards
  3. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear, easier to replace now, if worn, than have bearings or slides cause belt to break again.
  4. loop belt loosely around drum at wear marks from prior installation
  5. reinsert drum onto rollers bearings slides felts as installed.
  6. loop belt around motor pulley
  7. pull tensioner pulley against spring to end of its travel
  8. loop belt around tensioner pulley
  9. relax tensioner pulley to tighten belt
  10. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Notes
There are not many belt, felt, support roller sizes the local parts guy will have a belt, felt, roller to fit,
Tensioner pulley may not be in place, breaking belts often pull them out of their mounts, the pulley and spring will be lying on the case floor, there is only one way they fit in to their mounts so they are easy to reinstall
tensioner sketch is approximate, pulley may be on top run pulling down, or bottom run pushing up
the repair is easy, it takes longer to type or read this than it does to repair the dryer
Belts ~$14 Support Rollers ~$14/pair, felts/slides upto ~$25
New dryer +$200 - its a good repair
Sep 06, 2008 | Dryers
Whirlpool GSW9800PW Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
