I have an old Mac G4 computer which is occasionally will not boot. It acts like the hard disk does not start spinning. The specs for the computer follow: Hardware Overview: Machine Name: iMac Machine Model: PowerMac4,2 CPU Type: PowerPC G4 (2.1) Number Of CPUs: 1 CPU Speed: 700 MHz L2 Cache (per CPU): 256 KB Memory: 640 MB Bus Speed: 100 MHz Boot ROM Version: 4.4.0f1 Serial Number: QT21701CMHJ AirPort Card Information: Wireless Card Type: AirPort Wireless Card Locale: USA Wireless Card Firmware Version: 9.52 Current Wireless Network: linksys Wireless Channel: 6 System Software Overview: System Version: Mac OS X 10.4.11 (8S165) Kernel Version: Darwin 8.11.0 Boot Volume: Macintosh HD Computer Name: Robert User Name: Robert Wood (robertwood) ATA Bus: Maxtor 4D040H2: Capacity: 38.16 GB Model: Maxtor 4D040H2 Revision: DAK019K0 Serial Number: D24VL6FE Removable Media: No Detachable Drive: No BSD Name: disk0 Protocol: ATA Unit Number: 0 Socket Type: Internal OS9 Drivers: Yes S.M.A.R.T. status: Verified Volumes: Macintosh HD: Capacity: 38.16 GB Available: 9.93 GB Writable: Yes File System: Journaled HFS+ BSD Name: disk0s9 Mount Point: / SONY CD-RW CRX170E: Model: SONY CD-RW CRX170E Revision: 2.3d Detachable Drive: No Protocol: ATAPI Unit Number: 1 Socket Type: Internal Any suggestions on what action I should take - troubleshooting and/or preventive? Thanks! Robert Wood
  • Robert H Wood May 01, 2010
    Is it possible to get access to a manual online to guide me in replacing the hard disc?
    Is there a market for used or rebuilt hard discs for this machine. If so how to I access them.
    Thanks for your excellent assistance.
    Robert Wood
  • Robert H Wood May 03, 2010
    It was helpful.
    President:
  • 4,070 Answers
Hi! Please take a good look at the motherboard for any blown capacitors. If there are blown capacitors, the computer may not work properly or it may work but cannot perform well and most likely will shut down. This may be the reason why the hard drive stops spinning. But if ever the capacitors are all good and no sign of leakage then you can start replacing the hard drive for i believe that its going to die any time soon. Hope this helps and have a good one!
Posted on Apr 29, 2010
  • dj_relly999
    dj_relly999 May 01, 2010
    Hi! Yes there are aftermarket hard disks that you can buy and use for replacement. Good luck!
Lost power when changing computer name and key. no boot or sys disk. boots to apple logo and spin wheel. how to recover w/o loss of data
Try holding down the option key (ALT) when you boot up and see if you can see your startup disk. Good luck....
May 22, 2016 | Apple PowerBook G4 Mac Notebook
Changed my user name and password but now is it not accepting it or old one
Use the Operating System install disk that came with your computer to reset the password. You can boot from the disk by holding down the Option key while starting up your computer with the disk in the cd drive.
Feb 18, 2011 | Apple iBook G4 Mac Notebook
My Mac 12" starts with a noise of the disk that
Check for a failing hard drive
Trying booting from the Mac OS X install disc. insert the Mac OS X install disc. press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
Dec 07, 2010 | Apple PowerBook G4 12" 1GHz w/ Combo Drive...
No screen on start up on g4 notebook
Try reinstalling MacOS on your laptop, as far as I know, all Mac come with recovery disks. To boot of off a disk, make sure the disk is in the drive , reboot the computer, and press C while the chime is playing. You SHOULD be able to reinstall. What your describing usually happens to very old iMacs that have bad, incompatible, or no RAM installed. If none of the above works, take it to an Apple Store, they were very helpful when my iPod had a bad battery
Aug 15, 2009 | Apple PowerBook G4 Mac Notebook
When i boot it up it makes a type of spinning sound in the computer then a screen pops up and shows a question mark flashing
sounds like the hard drive may be bad. Kind of like the heads are banging together, try a different hard drive in there and reset the laptop back to factory defaults. If you have the disks, i'll walk you thru it.
Jul 17, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook G4 Laptop not starting :-(
sotware is awry 1. put in your system disk and restart holding the c key 2. when the screen shows hit continue 3. go to utilities in the header menu 4. select disk utilty 5. select repair permissions 6. select repair disk after the permission repair is complete 7. quit utility go to start up disk  select your hard drive and restart good luck
Apr 01, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook won't start up
If you have the original install CD or the OSX CD, boot to CD. To do that you must insert CD, restart PowerBook and hold letter "C" on keyboard while computer is starting, then take the first steps towards installing the OS, when you get to the bar on the top go to Tool>Utilities>Disk Utilities then select the drive a do a disk repair. That may fix the problem and bring your system back to booting normally.
Mar 15, 2009 | Apple PowerBook G4 Mac Notebook
Screen won't turn on
when the computer boots does the screen light up? if it does the first thing you need to try is when you turn the computer on is to option boot. That is done by holding the option key while turning the computer on. after it boots you will see the the hard drive listed on the screen it will be a icon, if there you should be able to boot up. If the computer does not boot and your hard drive is still listed you most likely have a logic board aka mother board issue.
Jan 11, 2009 | Apple iBook G4 Mac Notebook
My Aluminum Powerbook G4 wont boot up
Insert the system CD, restart the computer holding down the C key until it boots using the CD. Then run through the initial screens as though you are going to reload the system software until you are given a menu bar. Select Disk Utility from the menu bar when you can and then you can run disk first aid and 'Repair disk'. If this works OK then you are back up and running after a restart. Otherwise you will have to reload the system. Note: when you have booted of the CD, you should be able to access the hard disk and retrieve any files you want first to an external disk or memory stick before reinstalling the system software. Good luck - TT
Dec 03, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
