Question about Refrigerators
Hi, I have GE side-by-side refrigerator model GSS23QGTA WW from 2006. I recently fixed ice frost build up on the frezer section and not cooling enough issue by diagnosing it using Fixya's experts' help. I think you all for that. I had to replace the control board and the defrost heater(which I suspect was the problem). Things are working again except.. While replacing the defrost heater, I noticed that there is a qtr size hole on the metal floor just beneath the heater. Then I found that there should have been some water collecter pan which the refrigereator never had. So I closed the hole by putting in aluminium paper (the on you use for metal vent pipes joints). So, now I get water from the defrosting by the heater(the way it may supposed to work), in the botom of the refrigerator freezer section down below every morning. I throw that everyday. Sometimes, a bit of defrosted water flows out on the floor. I need to fix this. So I was thinking of taking out the Aluminium paper from the above mentionde hole. But then that water will drip out from the hole on the floor anyways. Right? What is the purpose of the hole and where should that water from defrost go? Please advise.
  • Max2010 Apr 30, 2010
    It does not look like there was any drain tube there. Should there be? Can you say it definitively please? If there is figure of that from service manual that is even better. When I read about it, I did not see anything connected to the hole. So not sure.. Should it be connected to any drain pipe? Is that typically the case with this model refrigerator? Please advise.
    Apr 30, 2010 - Hi, I have GE side-by-side refrigerator model GSS23QGTA WW from 2006. I recently fixed ice frost build up on the frezer section and not cooling enough issue by diagnosing it using Fixya's experts' help. I think you all for that. I had to replace the control board and the defrost heater(which I suspect was the problem). Things are working again except.. While replacing the defrost heater, I noticed that there is a qtr size hole on the metal floor just beneath the heater. Then I found that there should have been some water collecter pan which the refrigereator never had. So I closed the hole by putting in aluminium paper (the on you use for metal vent pipes joints). So, now I get water from the defrosting by the heater(the way it may supposed to work), in the botom of the refrigerator freezer section down below every morning. I throw that everyday. Sometimes, a bit of defrosted water flows out on the floor. I need to fix this. So I was thinking of taking out the Aluminium paper from the above mentionde hole. But then that water will drip out from the hole on the floor anyways. Right? What is the purpose of the hole and where should that water from defrost go? Please advise.
    I got suggestion of putting in a custom tube with funnel and sealing it. It sounds logic. But the refregerator should not need any such thing. I replaced the motherboard/control board, I replaced the heater. I know the defrosting seem to work becaus the frosting melts creating water. Where is supposed to this water be drained. I do not believe GE would have you create drain pipe. How it is supposed to work. Frosting is not mal phenomemn, so water from melting is the normal. All I am trying to understand where the water is used. Doe that get evaporated or used as cooling for the motors below. what is the engineering behind this hole? If there is a hole then there is expectation of water draining thru it. I temporarily closed it, not knowing why it is there. I am just trying to understand the engineering behind it.
    Guru:
  • 415 Answers
The water should be collected after defrost and routed down to the bottom section of the refrigerator into a collection pan that is normally in the airstream of the condenser cooling fan. The water typically evaporates into the atmosphere.
Click HERE for information on your refrigerator to include a component breakdown. Under the heater, the water should drain through the hole and then through a drain tube and into the bottom of your refrigerator to be evaporated.
I hope you find this to be helpful. I will look forward to hearing back from you. :-)
Posted on Apr 30, 2010
  • laura Newman May 01, 2010
    Hi Max.
    The water will need to go somewhere; therefore, there is a drain hole for the water to drain out of. It is then channelled down to the bottom tray where it will evaporate. It is channelled via the drain tube. :-)
  • Refrigerators Master
  • 12,061 Answers
Http://appliancejunk.com/ge/refrigerator/31-9072.pdf
Ok above is a manual this should show you what to do. To my mind, you shouldn't have ANY real amount, say anything over a 100-200 mL of water on the floor or anywhere else for that matter. But in saying that, they do have "Catch Trays" underneath, I guess. If you cannot "Fix" it, and perhaps that's just the way it is, then, as a "Fix" you should get some sort of Funnel, attach a pipe to it an run it outside, Push the Funnel, into the "Hole" cut it off flush, seal it all around with GOOD waterproof, sealer/glue. At least for now, the water will just drip outside, into say into a drain. But really you need to find out "Why" it is making even this modest amount of water. It may just be a "Watery" machine though. I have done similar thing before to remedy situations similar, with Fridges, Freezers, Cool Rooms, & Air Conditioners. Anyway use the Service manual, and maybe try my Water routing idea. I just used about 10' of clear plastic tubing about 1/2" (Whatever fits on the small funnel) & a small Plastic.Funnel, it works great every time, and gets that smelly water away, outside where it belongs.
    President:
  • 2,468 Answers
It sound as if your missing your drain tube in that spot where you say that quarter size hole is and this should lead down to the defrost water collection pan you say you never had either
Posted on Apr 29, 2010
GSS20IEPA WW frezer is cold but refrigerator is not
The most probable thing that will cause the frrezer to work is a failure of one of the components of the automatic defrost system. Do you see frost built up on the back wall of the freezer?? if yes their is frost build up on the freezer wall it is a defrost failure and this tip i wrote will tell ya what to check to see why its not automatically defrosting.
http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Sep 18, 2011 | GE GSS20IEP Side by Side Refrigerator
Side by Side GE Refrigerator freezer will not defrost which allows frost/ice to build up. I have cleaned all the areas behind the unit as well as under the unit. After I manuely defrost the freezer it...
The defrost circuit has failed in your fridge. Typical failure is with the defrost heating element. To troubleshoot, you need to remove the remove the contents of your freezer section and remove the freezer back panel to access the evaporator coil. You will need a hair dryer to melt the ice on coil. The heating element is attached to the coil. Use a meter to confirm that the element is bad. Hope this helps you.
Nov 08, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Stop cooling every 5 days I defrost manual GSS201ETCBB
Does the freezer / fridge door close good? Check the hinges. Also check the seal and the amount of food stuff you may have close to the door. If you have an ice maker make sure you have it secured inside the freezer section.
It sounds like something is keeping the freezer door open or from closing good.
Mar 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Refrigerator won't cool and freezer has ice build up on back.
its a defrst problem most likely the defrost thermister wr55x10025
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refriferator cooler side is warm/warming
possible cause the fan motor that takes air from the frezer section may not be working or seizing up check to see if your fan is working after seting your dial at corect numbers thans from gilles
Mar 15, 2009 | GE GSS20IEP Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost in Freeze
Hi Frezer Frost.
It sounds like your defrost circuit in the refrigerator has gone south. This melts the ice off of the cooling coil in the freezer section every 8 - 10 hours of run time.
If you are old enough to remember the manual defrost refrigerators, that is why you had to defrost them occasionally. The ice layer on the coil acts as an insulator, preventing the coil from working properly.
Greg.
Aug 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE not working
Change the defrost heater, It's located at the bottom of the frosted coils and should have a pink and blue wire running to it.
Jun 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
FRESH FOOD COMPARTMENT TOO WARM
it could be a defrost heater problem . the heating cycle is not defrosting the ice that is why your having frost build up. the heater could be damaged, thermosdisc damaged, electronic timer module damaged.try thawing it up by unpluging it for a day or two until there is no more water dripping at the back then try it again, im sure the refrigerator section would cool again for a week or two before it wouyld go back to the same problem. dont forget to bring back the setting to 5 for freezer and 35 for refrigerator in order for the thermostat to work.
Feb 04, 2008 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
