Question about Intermec EasyCoder® PF4i Label Printer
Intermec PF4i will not feed labels? The printer trys but the roller do not spin to feed label and i get paper fault error?
    Scholar:
  • 118 Answers
Check to see if anything is blocking the rollers, sounds like a piece of paper is jammed in there
Posted on Apr 29, 2010
How to adjust intermec to print thicker labels
Only user Intermec Labels or they will probably not work.
Feb 20, 2012 | Intermec EasyCoder PC4 Label Printer
Paper fault with intermec pm41i
Sound like you need a new label or paper sensor. We have inhouse technical teams who can repair this problem for you. jack@codeo.co.uk 01179064587
Nov 08, 2011 | Intermec EasyCoder PM4i Printer
Intermec PX4i label printer. Paper/Ribbon loaded correctly, but ribbon is 'rippled' meaning barcode label being printed has white lines across it. Any ideas?
Ribbon Wrinkle as it called can be caused due to the main feed rollers (that touch the ribbon or the label) being slightly worn. Even if you have a sligh gradient on the roller(s) it will pull ever so slightly to one side. If you need the parts then please do not hesitate to contavct me. Jack Woodworth - Codeo UK, 01179064587
Oct 19, 2011 | Intermec PX4I Label Printer
Labels are printing too small
This printer is available in 203 and 300 DPI (Dots Per Inch) resolutions. I'm guessing that you have a 300 DPI printer and are using the printer with a 203 DPI driver. This would result in your labels being printed "small". Check to see that you are using the proper driver.
mikeo@acebarcode.com
Feb 18, 2011 | Intermec EasyCoder PF4i Printer
I am getting a paper fault error when I load a continous paper stock, is there a way to chante the settings to fix this.? My prnter is an intermec PX4i
I hope this helps, this is the solution of there website. If this isnt your problem please respond and i will assist you further.
The Label stock must be fed between the upper and lower guides plates. The path that the label must follow is shown on a sticker inside the media cover. If the media cover is missing download the manual
by clicking on the link below. Verify that the green label guides are adjusted so that the labels stay against the inside wall of the printer.
Depress and hold the Shift Key then press and release the Feed key. The printer should feed some labels during which it performs an auto calibration of the sensor. If the error continues perform the following.
Both the upper and lower sensor halves are mounted on an adjustable bar assembly. The upper and lower guide plates slide over this assembly and can easily be removed for routine cleaning and inspection. Should the sensor window in either half of the guide plates be scrached or damaged, it must be replaced.
The sensor is adjusted by a slot head screw located under the metal lever opened to gain access for loading labels between the guide plates. Once opened the adjusment screw is exposed.
Once you have verified the the following and the problem persists then the sensor is itself is possibly the problem and Service should be contacted.
1. stock is loaded correctly.
2. Sensor assembly is adjusted out over the label.
3. Sensor and guide plates are clean and clear of debris or defects.
4. Configuration settings are correct (label length and media type, gap,mark or continuous).
This is the link to the 501 XP users manual
http://epsfiles.intermec.com/eps_files/eps_man/96042502.pdf
Sep 21, 2010 | Intermec EasyCoder® PX4i Label Printer
I am getting a paper out message all the time. I have Intermec 2-1 labels loaded at the moment
Reload back the fingerprint firmware v8.78.1 into the printer.and try to press shift button together with feed button.
Jun 29, 2010 | Intermec EasyCoder® PX4i Label Printer
IS THERE A MASTER RESET ON THE PF4I OR A FACTORY RESET
Hold down the F5 key while powering on and hold till it beeps. Then hit F4, F2, F2, F1 and ENTER for factory defaults
Feb 18, 2010 | Intermec EasyCoder® PF4i Label Printer
How do I find the MAC addess
> Click on start then click on run and then type cmd
> Now type ipconfig/ all
> Your mac address will be appear their as physical address
Good Luck
Jan 13, 2010 | Intermec EasyCoder® PF4i Label Printer
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
Intermec EasyCoder® PF4i Label Printer Logo
515 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
