Question about Dishwashers
Water is not coming out. I have checked the spray arms and they are turning ok. All valves are on to the dishwasher. Any ideas?
    Novelist:
  • 145 Answers
The fill hose to the dishwasher goes into a solenoid valve to fill the dishwasher. Check to see that it is opening. You can check this but starting the dishwasher and listening, a solenoid valve will click open and shut. If not it needs to be replaced. Note: It helps to pull the machine out from under the counter to listen for this. Also, although not as likely, hard water sometimes can clog the water openings on the spray arms, CLR or Lime Away can take care of that (Take care to rinse and drain the dishwasher after using these products).
Posted on Apr 29, 2010
LG Dishwasher water flow is weak coming out of the lower spray arm. No water coming out of the upper spray arm. I changed the water inlet valve, and there isn't any difference.
There is a possibility the water pressure itself is low from the kitchen line or the dishwasher is set at incorrect water pressure setting and does not collect enough water based on the flow time of inlet valve. If you hear the wash motor cut in then there is not enough water in the base to start pumping it to through the arms.
Apr 11, 2014 | LG 24 in. LD-12BS6 Stainless Steel...
Water not spraying out hard enough
Check water inlet valve (solenoid) for a clogged inlet screen and for proper operation (ensure full opening of the valve); check the main(undersink) water connection for an obstruction or partially closed valve, and check the lines/tubes throughout for obstructions - scale, collapsed line, etc.
Oct 04, 2012 | Amana ADB1600AWW Builtin Dishwasher
Dishwasher does not spray water just trickles out.
Ok this normally happens when there is a leak in the base
pull it out and remove both side panels
Do you see any water in the base
look on the left side there is a red bar which goes down to the botton lift this up and down you should hear the swich clicking make sure the rod is down then retry it
The micro screen maybe clogged but the main culprit may be the larger filter found inside the unit upon which the spray arm sits. It has sometimes significant calcium type deposits that I nearly completely cut off the water flow.
http://www.acmehowto.com/howto/appliance/dishwasher/check/sprayarm.php
Link above is how to check, your spray arms, to test.
Water comes into the dishwasher not through the spray arm.
It comes through the water inlet valve out of the hole on the left side of the tub.
The lack of the pressure could be if it is not enough water came into the dishwasher during the fill up time.
Add a 1/2 of gallon of water manually and see how the spray arm spins. If it spins better then the next step is to check the water shut off valve under the sink. Is it open all the way or not?
If it's fine then the problem is the water inlet valve. It could be blocked with hard water deposits or it's not opening all the way. In both cases it has to be replaced.
Apr 08, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
THE UPPER TRY DOES NOT GET CLEAN, THE SPRAY ARM ON THE BOTTOM OF THE UPPER TRY AND THE SPRAYER AT THE TOP DO NOT TURN?THE WATER THAT COME SOUT AT THE BOTTOM IS WEAK ? WHY?
It could be that your dishwasher is not getting enough water. Let the water fill the dishwasher, set the spray arms in the same direction. Add a large pot of hot water and run the dishwasher. Open the door and check to see if the spray arms have moved. If they have moved, replace the water inlet valve.
Remove the 4 screws holding the lower kick panel. Remove kick panel. Locate the water inlet valve. This is the electrical valve where the water pipe hooks into the dishwasher. Shut off the water to the Dishwasher and electrical to the dishwasher. Disconect the 2 wire plug at the water inlet valve. Disconect the water supply to the dishwasher at the valve and disconect the rubber hose attached to the valve. Install new valve and test machine.
I hope this helps.
Jan 05, 2010 | Dishwashers
My dishwasher is not cleaning dishes - it is running through its cycles, but when it is done, there is a heavy residue of soap and hard water and the dishes looks worse than when i put them in.I've changed...
Hello there:
There are 6 areas that could cause this to happen Please follow these simple steps ok
Investigate each of these six areas if your dishwasher is not completely cleaning your dishes:
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Cycle Selector Switch
Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
Dec 30, 2009 | Kenmore 15899 Built-in Dishwasher
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
Heating Element
Filter/Drain Grate
  • filter
  • . Detergent or Detergent Cup
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Mar 29, 2009 | Dishwashers
    Spray arms don't spin on Smeg DWF 410 ss
    Remove he wash arms and visually check for obstructions in the holes where water sprays out if any number of these are blocked it will happer the turning of the arms
    Jan 21, 2009 | Smeg 18 in. DWF410SS Slim-Line...
    Bosch SGS45E08GB dishwasher Lower spray arm not turning. Have removed and cleaned still not turning any sugestions?
    same problem, any ideas as to where the sensor is and the valves that control the flow? i have no water at all getting into my bottom spray arm :(
    Jun 23, 2008 | Dishwashers
    Dishwashers Logo
    61 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
