Question about GE DWSR483EBWW Electric Dryer
Shuts off too soon when the clothes are still wet
    Habit-Forming:
  • 98 Answers
Make sure the door does not come open while running.
If it turns off only during the auto-drying cycle, the moisture sensor may have failed.
If it turns off during the timed cycle, the operating thermostat has most likely failed and the high limit thermostat turns the machine off when it gets too hot. After the machine cools down, it will start until it heats up and turns off again.
Posted on Apr 29, 2010
Maytag dryer se1000 runs for 15 minutes then shuts off
Clean your sensors if you have them. They might have junk on them that could be forming a moisture barrier preventing the sensors from feeling the wetness of them clothes. The dryer may think them clothes is dry because it cannot sense wetness.
Oct 05, 2012 | Dryers
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
The dryer turns on but isn't warming up so clothes are not drying.
Look for goop on the dryer sensing bars. get some windex and clean them . The moisture sensing bars send back resistance readings to the control. No moisture sensed and the control thank they ain't no wetness in them clothes, it goes for cooldown and shuts down with wet clothes.
thats one scenaio. if that don't fix it we will go to the next step. let me know
Feb 10, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer door opens before cycle is finished
The clip on the door is just been used to much, using a small flat head, (if the clip is metal only) you can twist and expand the eye of the clip, if it's plastic and looped you can stick toothpicks and use em as shims to expand the hole. usually the eye has been crimped shut not letting the clamps grab and the wet clothes knock the door open shutting the dryer off. Usually when you got a date or big job promo soon and you were not there to notice the flaw and you find your clothes still soaked ten minutes from the time you were gonna go. LOL
Jan 20, 2011 | Miele Novotronic T1515A Electric Dryer
My maytag duet electric dryer is heating, all controls seem fine, we cleaned out the lint traps, checked the hose and blew out vent as well. The dryer keeps shutting off early before clothes are dry. They...
Your moisture sensing bars may have junk on them. The way your machine detects drynesss ir with we clothes.
As them wet clothes rub them bars they short out the board and that way it knows them clothes need a bit more time.
If thm bars get a bit of softener oem and glaze over the bars then wetness won;t be detected no more and the control won't know them thangs is wet or dry and most likely declare a No Joy.
Dec 10, 2010 | Dryers
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
NO HEAT WHEN CLOTHES ARE ADDED
Check to see if vent hose is not restricted. If it goes up inside wall, it could have lint clogging it. Most dryers regulate heat with air flow. Wet clothes can restrict flow even more if vent is clogged or pinched. Air flow is crucial to heat cycle. If the vent is resrticted, heat will rise quickly, but not cool down fast enough to allow heat thermostat to cool down and turn on heating element again. It may seem hot inside dryer but if no air flow it will increase dry time or not dry them at all before timer shuts off. If vent goes up inside wall, buy a small chimney brush and try cleaning out vent from attic if you can.
Jul 24, 2009 | Maytag MED5800TW Electric Dryer
Whirlpool Ultimate Care II does not completely drain.
Mine will do this if clothes are left in it for a long period of time. The pump will not drain all water out because the will dry out the seals if they do. Your wet clothes dripped in the tub raising the water level to the bottom of the drum and that is why you have wet clothes. Remove clothes as soon as they are done, use cycle signal to avoid this.
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
F1 flashes on dryer and shuts off before clothes are dry
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
Nov 16, 2008 | Dryers
GE DWSR483EBWW Electric Dryer Logo
232 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
