Question about Peg Perego John Deere Farm Tractor and Trailer
2950 JD my pto handle will not stay engagen it just falls back to off position
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Wrong forum
Posted on May 22, 2012
JD 1026R tractor. Why the PTO does not work?
many of this type machine will not engage the PTO if the battery is not full charged or bad
Apr 17, 2016 | Garden
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
Jun 24, 2015 | John Deere Garden
On a rzt 42. The pto clutch bolt loosens and clutch falls off with use of 10 minutes or less. How do I fix?
The PTO clutch has a bolt that goes through it and into the vertical shaft of the engine. MANY of the PTO clutches have a large spacing washer that goes on before the PTO clutch is slipped onto the shaft. If the washer was lost when the clutch was changed, the bolt might be bottoming out in the shaft rather than tightening on the threads like it should. I'd get a diagram for your model and make sure all parts are in place.
Jun 05, 2014 | Cub Cadet RZT S Series
While cutting grass the pto clutch cuts off, i have to push switch in and back out to restart blades. I have replaced the switch and pto clutch
Check operator present switch under seat. Perhaps you'r moveing and not staying on switch. Check wires to pto, and seat switch.
Aug 18, 2010 | Oregon Scientific Electric PTO Clutch for...
Jd 3020 power shift pto turns all the time. if lever not engaged a heavy load can stop it. otherwise it works ok
The pto brake is either worn out or you have no presure to it when the pto is turned off,most likely the pto brake is worn out.
Nov 03, 2009 | John Deere 3010,3020 Tractor Basic...
I have a JD 1070 4 wh dr, when running a brush hog on the back pto, what would make the pto shaft slow down under a load when cutting light brush, funny smell. Checked all oil levels.
Reading on line, I see your tractor has a PTO clutch. It must be slipping. It either needs adjusted or replaced. A slipping clutch disc will make a bad smell.
Jul 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Pto won't stay ingaged on 1641 tractor 1993 year with briggs eng.
the clutch may need adjusting the clearence should be 10 thou you measure with a feeler gauge through the three holes on the side and adjust with the three nuts
Jun 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Peg Perego John Deere Farm Tractor and Trailer Logo
201 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
