Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
My Samsung Syncmaster 943BX will not wake up from sleep mode sometimes. Sometimes it comes right up, other times it may be 5,10,20 minutes before the display wakes up.
  • 11,361 Answers
You probably have caps failing in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 29, 2010
How to wake Dell All in One, Win 7, from sleep mode
In Windows 7, there is a bug, if you put the PC in sleep mode when the system is running on batteries then it may still drain out the batteries and you cannot wake it up. In this case, you need to connect the AC power and reboot the PC. If you put the Pc to slepp when the AC power was connected. Then there are no issues and just by pressing the enter key it should come out of sleep mode. Sometimes - depending upon settings - you may need to press the Power button the PC to wake it up from sleep mode.
If you have already tried all this, then please go to the Power settings in Control panel and check all the setups that exist. You may need to change some of them.
May 25, 2014 | Dell OptiPlex 760 MT Desktop Computer
It seems that my new Desktop PC encounter problems every time the screen is not used for 30 minutes or more. I have a Samsung SyncNaster 2033 monitor and a 1GB DDR5 HD5670 SAPPHIRE Graphic Card.
The computer is most likely going into a sleep mode after 30 minutes, normally you can wake it up by simply moving the mouse, or pressing a key on the keyboard. If the sleep mode is malfunctioning, which is sometimes the case, you can disable it by clicking start, then control panel, then power options, and on the left hand side you should see 'choose when to turn off the display'. It varies slightly for different versions of windows, but what you're looking for will be in the control panel under something mentioning power. The instructions I've given are for windows 7
hope this was helpful.
May 30, 2011 | Samsung Syncmaster 2033SW Monitor
Samsung syncmaster 226BW fails to wake up.
If pc not sending it to "sleep mode" or "power save" mode, then unit may need help of electronics technician to investigate the "internal switch-mode-power-supply" that may be going into "shutdown" mode after it detects a "fault condition" with itself or onother circuit.
12fixlouie
Sep 20, 2010 | Samsung SyncMaster 226CW 22" Monitor
My computer goes to sleep and sometimes I can't wake it up.
When is asleep try to close the lid completely and open it again. This works for mine sometimes.
Jul 23, 2010 | Dell Inspiron 530 Desktop Computer...
I can't get my Samsung SyncMaster 931BF to come of of sleep mode?
I already post solution for this problem, click here to see the solution.
Dec 21, 2009 | Samsung SyncMaster 931BF LCD Monitor
My phone goes to a sleep mode and refuses to wake up.
Mine does that sometimes too. If you just press and hold the button for about 3 seconds, it will turn on within 15 seconds.
Apr 01, 2009 | Samsung Omnia Cell Phone
Laptop goes into permanent sleep mode, etc
If you can restart it and it starts up fine, then I would go into the power settings and disable sleep mode. Every computer is different on how to wake a sleeping computer, so you could read through your manuals and find out for yours, but I just disable sleep mode on all computers so i dont have to hassle with it.
Dec 30, 2008 | Computers & Internet
Power on
connect the monitor to pc and press the power button to make it to the power on mode. you must have used your keyboard to make it on sleep mode.
Dec 12, 2007 | Samsung SyncMaster 403 T 40" LCD Monitor
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
1,250 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
