Question about Initial DTV-172 17 in. TV/DVD Combo
TV not listed as AV signal source
Has been working fine, but one morning went to turn it on and screen black. Discovered "TV" is no longer listed at the top when you push the 'AV signal source' button on the remote. It's like it no longer recognizes the tv. Nothing had been touched.
I have the same problem!
Posted on Oct 07, 2010
Have Sanyo DP50740 Plasma tv and Dish Network receiver. This morning I turned TV on and receiver on and Black screen appeared on TV with floating no signal box with white letters. I do not have the t
Check the TV first by tuning it to an external RF source; ie; on-air program by connecting it to external Ariel and make sure that the TV is OK. If the TV works fine with on-air program, the Dish Network receiver is either fault, of it do not get input signal.
Oct 18, 2014 | Televison & Video
52" RCA Rear Projection TV- When turn on the screen seems to be split in 3 horizontal bars all scrolling. The color doesn't seem to be there either, but hard to tell. When I put up the menu
Good Morning
if you remove the signal either being HDMI or Av Cables from the source are the bars still there ? if they are id suspect a signal board problem . if there not try unplugging your signal source for 5 min's and then do a restart if problem still exists then contact your service provider for further assistance .
Oct 15, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
How can i turn on the av channel on a sony trinitron KV-25F1U
Hi, look for a symbol either on the front of the TV or remote that shows a Circle with an arrow pointing into it from the left
Mar 21, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
LCD Scree went blank/black
No problem. Discovered that fix by accident when my camera did the same thing. Since the screen was blank, tried arranging camera setting using the camera's AV cable with the TV, and discovered that fixed it. Apparently corrosion builds up on the AV cable plug switch (which also turns the screen off when inserted), and inserting/removing the plug several times can fix it.
Jul 10, 2009 | Canon PowerShot SD10 / IXUS I Digital...
The dogs rolled on the remote and the tv went to a blue screen and turned off. Every time you turn the tv on now it is a blue screen and says no signal and turns off after 10 seconds
This sounds as if when the dog rolled on your remote he has pressed the source button so that you are no longer on the TV cahnnel. The TV is looking for a different input eg. AV1/AV2/HDMI etc. This will give you a blue screen & as there is no signal the TV will switch off. Check on the remote for an Input or TV/AV or source button & make sure this is set for the TV signal.
Mar 22, 2009 | Vizio Televison & Video
Nothig bu a blue screen shows when turned on
Blue screen of Death?
No, this is not windoze.
can you change channels?
a blue screen usually means that you don't have a signal.
Is it hooked up through dvd/vcr player?
Try a straight connection to cable or antenna.
If it remains, then it requires surgery.
Sep 30, 2008 | LG 42LC2D 42 in. LCD HDTV
Screen went black
Remove the front grey bottom panel of you TV (don't forget the 2 screws behind the front AV cover located just below the power button) then remove the panel behind the grey panel. You should see 2 heat sinks on the front right of your TV, place a fan near your TV and have it blowing on the heat sinks. Now turn on your TV and see if it stays on longer then it has been. If it does, your DC amps might be overheating. If they are, you might be able to fix your problem by adding in a little more heat sink compound between your DC amps and the heat sink itself. You can find the compound at Radio Shack for about $5. let me know if pointing a fan directly on the heat sinks helps.
Jul 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Black square
If the picture can be seen on the sides of the black square you need to go to the menu and find the text and turn it off
Usually in the closed caption section
Mar 12, 2008 | JVC AV-27230 27" TV
Initial DTV-172 17 in. TV/DVD Combo Logo
64 people viewed this question
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
