Question about RCA D61W20 61" Rear Projection Television
I also have the same problem, (Model # D61W20B - RCA Rear Projection TV) At first it would come on sometimes, then eventually you would have to sit for about an hour to get it to come on by continuing to push the power button, the light would blink a few times and power off. Then one day it just wouldn't come back on at all. I thought it was the bulb becuase we have another TV (65" Mitisubishi and it was just the bulb) after reading the comments that were posted I am not sure if it is the bulb or the deflection board. I am not sure if I should get a new bulb and waste the money or get a deflection board... i don't even know the part numbers for either item. What should I do? How do I fix it? HELP!! I just want it fixed... :-)
  • straitk Apr 29, 2010
    Yes Partially
    President:
  • 1,619 Answers
Best bet is to replace bulb, many online retailers have bulbs that you can install just do a search for your set. If it doesnt work call a local repair shop to check out the board. Its the cheapest way to go.
Posted on Apr 29, 2010
Hello i have a 60 inch RCA model number d61w20b serial number d505c10h3 manufacturer date DEC 2003. it has started cutting off by its self and the power light will flash 4 or 5 times. sometimes it will...
I suspect that you may have cracked solder connections on the deflection PC board. This is the module that has a red wire coming from the top of a transformer and leads to the front of the tv. I would start with a cleaning of the components, a soft paintbrush and vacuum work well for this. Remove the power deflection module carefully, turn it over and look for cracked solder connections on this PC board. especially near the high voltage transformer. Use a soldering pencil type iron and small diameter solder to correct the issue.
Jul 26, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen only shows red and green
i have 61" rca model # D61W20B
the pic was working fine then all of a sudden
got blurry
Feb 23, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 61" d61w20b, i can turn on the tv and the sound is good but the picture is not right it bows and distorts the picture, it shows the picture in three colors green, red, and blue could it be the...
What you most likely have is a convergence problem. The convergence circuitry is used to align your colors. What you describe sounds like that circuit has failed. Here’s a link to a decent video that will give you an idea of what is needed to fix it: http://www.youtube.com/watch?v=S6Wa8FvSz-s
Aug 30, 2010 | RCA D61W20 61" Rear Projection Television
Will not turn on RCA model D61W20B
the tv won't turn on with the remote or with the power button
Jan 30, 2010 | Televison & Video
TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Jun 21, 2009 | RCA D61W20 61" Rear Projection Television
RCA D61W20B WHEN YOU GO TO TURN ON GREEN LIGHT COMES ON FOR 3 SECONDS 3 TIMES, AND THERE ARE NO CLICKS OR OTHER NOISES, FOR AWHILE IT WAS HARD TO TURN ON. ANY HELP THANKS JIM
replace the flyback # 259296 and CP150 that should solve the issue. You can get replacement flyback and CP150 at the following link and they provide free instructions
http://servicemanuals.vstore.ca/
Apr 02, 2009 | RCA D61W20 61" Rear Projection Television
Rca d61w20b tv
Some set display this problem because of bad capacitors in the powersupply. Take a good LOOK at all large caps on the board.
Aug 06, 2008 | RCA D61W20 61" Rear Projection Television
Doesn't stay on
power supply is bad needs replaced
Apr 05, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
