Question about Amana ARGS7650SS Gas Kitchen Range
Have Amana Gas Mod ARG7302LL S/N 98101818Range. Seems the oven takes longer than usual to come on. Possible Igniter?
  • Amana Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 04, 2010
Oven wont light
Chances are you have an oven igniter that is not working - pilot lights are no longer used because of energy consumption. That igniter needs to be replaced for the oven to light up and function.
Sep 08, 2015 | Amana Gas Stove Range Oven Ignitor Igniter...
Baking oven won't ignite, broiler element works,
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 05, 2010 | Amana AGR5715QDS Gas Kitchen Range
I have an Amana AGR5715QDS and when I turn it on and set it for any temperature, lets say 350 degrees, it does not turn on or heat up. The stove top burners still work fine and the door appears to be OK,...
Feb 05, 2010 | Amana Ovens
Oven set at 350, won't get there. kitchenaid mod#kgrt607hwho.
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 30, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 14, 2010 | Amana Ovens
Amana ARG7302LL Gas Oven won't light ... how to troubleshoot issue?
Oven Problems Replacing the Igniter
heatman101
fjsj
Nov 03, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Oven slow to ignite and come to temperature.
Change the igniter.
As they age, they often times will no longer draw enough amperage to allow the gas safety valve to open. Increasing the line voltage would help, but that's a little impractical.
Jul 18, 2009 | Kitchen Ranges
F-2 code on Amana ARG7302LL gas range
it inside the oven its held in by 2 screws u should be able to remove them and pull it out and replace it . sometimes wire to short then u have to remove the back
Mar 22, 2009 | Kitchen Ranges
I would like to replace the oven door on my Amana gas range model ARG7302WW, is it possible?
Yes, its possible.
Remove the door from the range.
Place the door on a flat surface with the front facing down.
Remove screws held the inner door panel.
Remove the inner door panel and you should get access to the door handle screws.
- Here are the break down diagrams for the Amana range Model ARG7302LL
Jun 04, 2008 | Amana Kitchen Ranges
Amana ARGS7650SS Gas Kitchen Range Logo
340 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
