Question about EuroCave Comfort 170 1-Temp - Black Solid Door
Eurocave I have an old eurocave & it has a cold and warm thermometer. I'm not sure what the best setting are & I can't find a manual online. Any suggestions?
  • davetdunne
    davetdunne May 03, 2012
    Hi Momsuz,
    What is the model number?
    D
Contact wine enthusiast, they have fantastic customer service.
I just bought an old EuroCave on craigslist and contacted them, the fridge is at least 10 years old, but they tracked down and sent me a manual for it.
My model is a V140
Posted on Mar 12, 2009
Me Too. Anyone???
Posted on May 25, 2008
Idle adjust on Bobcat Diesel
Best Manuals Since it's a heavy equipment, I suggest you get one of these online books that help you do it yourself without any further help. My friend has been doing this for his farm machinery.
Dec 12, 2017 | Cars & Trucks
What am I doing wrong? I keep losing my outdoor temperature overnight
I can understand when it is very cold outside, the voltage of the battery drops below the point is can service the transmitter (in the thermometer). But if night temperature is not below zero that can't be the cause.
Be aware, even batteries that come with a new device, can be "old". you never know what the battery had to last, before you put it in the device.
I would advice to buy a new battery for the thermometer. Look in the manual, for what the manufacturer advices. But never use manganese (Zinc-Carbon) batteries. Although the alkaline batteries perform bad in cold, it could be the best choice.
Jan 05, 2015 | Springfield 91455 Wireless Digital Outdoor...
Humidity thermostat
I suspect the walls are warm and fooling the thermometers.
Aug 07, 2013 | Heating & Cooling
Too warm
First of all check to see if the compressor is running. If it's not running and you have no leakage of refrigerant. it is probably the start relay at fault, or the thermostat control is faulty. Check with a multimeter on ohms and check between common & start see what ohms it reads then check between common and run. see what that reads. then check between start and run, this should read what the other two read added together. if you have no readings then the compressor may be burnt out.
May 17, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator freezing lettuce. Adjustments result in freezer section too warm. I can't seem to find the correct settings. I can't locate my manual. This appliance is 25 years old or more.
a refrigerator thermometer is a good investment (usually available at grocery stores) .. i have two to make it faster to adjust things (one in freezer and one in refrigerator) ... first set the freezer with the temperature control .. set the freezer to 0 degrees F (adjust a little at a time until its close (wait several hours or a day between settings) ... then you may have another control called "air" or "refrigerator" .. you set that one for 37 deg in the refrigerator .. it usually takes a few days to get it right .. but without at least one thermometer you are flying blind, its nearly impossible to do correctly .. you can use any thermometer that is accurate down to 0 degrees, so you dont have to buy one if you already have one .. once you get it right you might want to mark the adjustments incase someone changes them ..
Nov 21, 2009 | Televison & Video
Thermometer
the cold control is located right behind the knob for the ref temp. the easiest way to diagnose the t-stat is to give it a good rap when the unit feels warm if it starts order and replace the cold control. drop down the control panel, the cold control has the long metal tube with the plastic cover, make sure to put it back in the same position when replacing, and transfer the white plastic cover to the new one.
May 05, 2009 | Refrigerators
Thermostat problem
is the refrigerator section is freezing up
Apr 04, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Thermostat location on York Diamond 90 gas furnace
Augold, sometimes its best to set the thermostat where you "feel comfortable" . I.E. set it and leave it til you feel the need to be cooler or warmer.
A thermometer on a thermostat will not always be accurate and setting it will only get it within 2 to 5 degrees which is enough to "feel".
Now from the stand point of is it working properly????
Assume you feel comfortable and the heat stays on to keep you comfortable is their anything wrong with this? I assume this is the goal. Even if it says 90 (and you know its not 90) and your comfortable you could leave it alone and be OK. If this kind of thing is whats bothering you a new thermostat may not be much better, unless your ready to invest in one and accept it however it should be closer to the place youd set it. Id recommend an electronic type they are more accurate and level doesn't matter so much to these types.
If you want to set the temperature and are determined to go by a thermometer to "feel Comfortable" I recommend you buy an electronic thermometer and set it close by the thermostat. Make sure you have no lamps or other heat sources close to the thermostat area.
Remember the far end of a room or a chair by a window Especially with little or no curtains and on the prevailing out door wind will always feel colder and be colder than the area by the thermostat even if both are in the same room. If your too cold try running the thermostat up a few degrees. If too warm set it lower. The equipment doesn't care how cold or warm it is.You will not increase your utility bills to the national debt by being comfortable
If this helps please grade me accordingly and Good Luck.
Mar 03, 2009 | Weather King 10AJA3601AH Air Conditioner
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
EuroCave Comfort 170 1-Temp - Black Solid Door Logo
1,025 people viewed this question
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
