Pc restarts and restarts till warmed up
My pc just keeps rebooting till it gets warmed up and then seems to run alrightany ideas how to fix before it gets worse?
Thanks in advance~Jerry
  • 7 more comments
  • threetyme626 Apr 29, 2010
    ty for the quick reply I will replace psu tonite and post my results....In clarification when i first start it for the day it resets and resets sometimes flashing a bsod, then like it warms up it boots and runs ok...
  • threetyme626 Apr 30, 2010
    Thanks again for your help....I swaped out the psu and same problem the BSOD says MACHINE_CHECK_EXCEPTION
    I cleaned and reseated the ram and graphics cards no help there either.. I am guessing mobo or cpu do you know a way to diagnose so I dont buy both? thanks in advance~Jerry
    what puzzles me is the seeming to run ok after the series of restarts..
    Problem has developed further...I decided to do a clean format/install of xp and after the format halfway thru the install got a bsod MACHINE_CHECK_EXCEPTION... ANY IDEAS ON HOW TO DIAGNOSE MOBO OR CPU??/sorry caps Thanks in advance~Jerry
    Thank you again for the help..I pulled the ram stick out and ran memtest86 on it for 8 hours ...no errors..
    I pulled the hd out and on another pc rad chkdsk /r twice ...no errors...tried the video card for an hour in another pc...ran fine...put all above mentioned parts in the other pc..no problems...i swapped the cpu with a known good one and am loading windows as I type...will post results...thank you again for your help~Jer
  • threetyme626 May 01, 2010
    Got to load windows and was loading programs and same problem...guess the mobo is the culprit...will post results..thanks for all the help~Jerry
    Well I changed the mobo and its been running for 3 hrs now without a hitch thank you for all the help and hope my trials help someone else...again thanks~Jerry
  • Adnan Bhatti
    Adnan Bhatti May 11, 2010
    Abnormal restarts are a classic symptom of a failing PSU. However its not the only cause. You should remove and reseat the RAM and add-in cards and if you have experience then do the same with the processor (NOT recommended if you have no experience of processor installation). BSOD is an indication that something might be failing like RAM or other addin component. Try starting up with only one RAM (if you have two) and see if there is any difference. do the same with other addin cards. Please note that dismantling a PC is not without risk. There is a chance of shock and damage from static electricity so if you are not confident then ask someone for help.
  • Adnan Bhatti
    I would suspect the power supply unit (PSU).
    President:
  • 1,188 Answers
There is a memory diagnostic tool from Microsoft. Search google for a download. Its run from the CD and check any issues with the RAM. As such there is no sure way to tell whether mobo is faulty. Bdw CPU if faulty will NOT run at all; only it can be over-heating. While formatting choose the quick format option not the extended one.
Posted on Apr 30, 2010
Testimonial: "four thumbs for the help...Thanks"
  • 2 more comments
  • Adnan Bhatti
    Adnan Bhatti Apr 30, 2010
    Click here for the link to the tool. You need to burn it as an ISO. Lets see if it helps. If you have two RAM sticks try booting with only one.
  • Adnan Bhatti
    I checked the Microsoft support website and this issue is explained in detail. Unfortunately this points to a failing or about to fail hardware but it cannot be said with certainty which component it is. I suggest you read this Microsoft article especially the tips at the end.Let me know about the results. Thanks.
  • Adnan Bhatti
    ...and also read this helpful Wikipedia article.
  • Adnan Bhatti
    Adnan Bhatti May 01, 2010
    Glad to know your system is up and running. You just gave me only 3 thumbs up. If I helped you out for free don't I deserve 4 thumbs up? Its the only way you can thank me as it boosts up my rating a little bit.
455ranger husqvara,i run it till it needs gas,it wont restart till an hour, sometimes it wont restart till next day. Do you know why?
Sounds like just too low compression. This will keep it from starting. Do a compression test and wright down the reading. Remember, when it's warmed up, the heat has made the cylinder expand a bit so the compression is going to be down. If the rings are warn out, that will drop the compression even more when it's warm. Fence the no start when warm.
Oct 28, 2017 | Cars & Trucks
How do I fix Sitting Ducks Croque Canards?
do a clean un-install, reboot and then restart the computer.
then try to see what happens .. if this does not work, then call 1-877-805-1027 for expert help//
Oct 10, 2015 | Computers & Internet
Dell d600 freezes intermittantly
sounds like the hard disk drive is slow to spin up. Sometimes older drives don't get all the way up to speed at boot, then with repeated restarts, the drive warms a bit and the spindle friction drops allowing full speed on the drive.
Try running HDD Diags the 1st boot of the day Fn +power button, see if you get any diag failure. Generally, a drive has to be within 3% of rated drive RPM (5400 or 7200) to function
Jan 11, 2010 | Dell Latitude D600 Notebook
Computer started restarting at random
its software related issue if you fdisk format and reinstall it should fix the problem just to double check if yu have another HDD with a OS already on it and plug it into your system it won't keep restarting
Mar 26, 2009 | ASUS Computers & Internet
I cant open norton, i just got help from a a tech person yesterday and now my computer is having alot of errors
Go to
http://service1.symantec.com/Support/tsgeninfo.nsf/docid/2005033108162039
Follow the instructions. Then...
Go to http://update.microsoft.com select "custom" and apply ALL the update it offers. Reboot the PC and go there again. keep doing this until it does not offer you any more updates.
go to http://www.spybot.de download and install spy bot. Run it and "fix" (press the fix button) everything it finds. reboot the pc and run it again. keep doing this till you get a clean run.
Then think about reinstalling it or read this http://www.jimmyr.com/blog/Norton_AntiVirus_is_A_Virus_97_2007.php and goto
http://free.avg.com/ and install AVG
Nov 13, 2008 | Symantec Norton AntiVirus 2002 8.0 for PC
Cannot print at all from the pc
Aug 10, 2008 | HP LaserJet 2550Ln Printer
Shutdown problems
boot your pc then follow the steps
start-run-msonfig(type in run command box then hit enter) in msconfig dialog box go to startup-disable all then click apply then click ok reboot,it will take some to reboot, then a message come just clik ok.
when your pc reboot again you restart now you check if the problem is solved
if you want any help fell free to post
May 17, 2008 | Computers & Internet
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
