RE:LC321SS9 The set, at start up, only shows a bunch of various color vertical bars. Reminding me of "Modulation bars" in the analog days. After some time it will start to show a picture which expands and compresses. It can then go to a full picture, but only show 1/3 of the screen three times. Finally sometimes it will settle and offer a good picture. Audio will cause any picture to revert to the start up picture I suspect my power supply may be on it's way out. I checked the "Menu" and found nothing to allow me to do a self check of components. Where can I obtain parts? Any ideas? David Clark West Palm Beach. FL
  • 1 more comment
  • n2hyc Apr 29, 2010
    That is all well and good, but if it is a capacitor, why will it straighten itself out after running for a few hours?
    Also WHERE CAN I OBTAIN OTHER PARTS?????
    TY I don't know why the first guy didn't tell me where to get the parts. I think you may be on to something because I noticed today if I move, or tap it strange things start happening which leads me to think something might be loss. With that new info are you staying with the signal board?
  • n2hyc Apr 30, 2010
    Because the problem is exacerbated when increasing volume a bad PS seem like a worthwhile investigation. I say that because with no audio pulling on the Power Supply what it can produce can be channeled to the Video side only,
    Sadly I also agree with the cold solder, or other damaged connection the intermittent nature of the problem certainly could fit, and as you say finding an incomplete or otherwise faulty solder joint does sound like something above my pay grade.
    So the final question is should I/can I check the PS with a VOM for example, or is it a R/R with another PS?
    Thanks,
    David
  • 666 Answers
Im going to give you a link to the parts directory it should be easy enough to find in there . There is also a download for the manual which may aid in contacting the manufacturer about having a repair tech come to house or take it in if its still under warranty
hope this helps
http://www.plccenter.com/sm/mfr-list.aspx?mfr=sylvania&source=Yahoo_TopWords&OVRAW=Sylvania%20LC321SS9%20parts&OVKEY=sylvania%20part&OVMTC=advanced&OVADID=33582765521&OVKWID=274139726021&OVCAMPGID=6318339021&OVADGRPID=13856701909&OVNDID=ND2
Robb
Posted on Apr 30, 2010
  • 3,866 Answers
# letter here OMG What are these experts saying to you. If you tap the set and things happened you got a loose component on one of the boards sounds like the H board. Capacitor oh lord where do these experts get off listen I been in the repair field long enough to know if a capacitor was giving yes it will cause strange things only after it heats up WOW!.
OK you need to take this to a qualified expert. If you ask for you money back on here I do not blame you one bit!! Shoot i'll give you the email to do just that but if your willing to listen to me and pay me for my advice we would not have to do this. I am glad you got a second opinion. Sure check the capacitors but if you bang on the tv and things go wicked you got something loose like a solder joint or cracked lead...
I am awaiting for your comment.
oh for parts www.partstore.com!
please do accept if you like my advice do not accept garbage answers from people that do not know this tech.
  • Grand Canyon Tech
    Grand Canyon Tech Apr 30, 2010
    I just looked up your model and man!! your having the same problem as many people has. Loose solder leads from poor or rough shipping and that would be in the power supply and the decoder/tuner board what that other dude is calling the signal board.
    You need to have a tech go in and rework!! This is going to need a rework solder job because of the 3rd layer pcb risk and non lead solder...
    I bet one of the component's is shorting out another or is so darn loose its not making contact.
    Please do yourself a favor you do not even have to accept me! But take your tv into a local shop do not listen anymore to this capacitor junk there just reading in between the lines here. there not seeing the full scope like I am. I am very apologetic on behalf of my fellow experts and Fixya.com
    As moderator here I implore you to take you tv into a shop or if you know what your doing rework you boards. Your PSU board and your decoder/tuner boards. You might have a shorted out IC we do not know its too early to tell without a look.
    please accept the solution if your satisfied!!
  • Grand Canyon Tech
    David,
    I do not know why we are ruling out the PSU without the thing opened up?
    The power supply needs to be H-pot tested you cannot just fish with a VOM to entertain the fact it may be bad.
    You strongly need to check solder leads and any loose things inside.
    My final answer here:
    Check anything loose then check you power supply but I would go with a new PSU if that was fact.
    Thanks for you time and ratings
  • Televison & ... Master
  • 1,212 Answers
Try Vancebaldwins.com. This will guide you near the place you ask for. Hope this will help. Also try the PartStore.com. This is a good start also...Good Luck. I would guess you may have a signal board that is on the fritz. Never worked on this brand, but would be my first point of interest to investigate. Thanks for asking!
Posted on Apr 29, 2010
  • 4,889 Answers
This actually sounds like there are faulty caps on the audio/video main board. First inspect the board for any cracked, leaky or swollen(at the top capacitors). If you don't find any you will need to get a multimeter set it to capacitance mode, range of 10mF and then test the caps one by one and see if any of them read "OL". If any of them do then they have to be replaced. I have fixed a similar problem in my shop couple of weeks ago and I am positive that this is capacitor related. Note that you have unplug the tv and discharge the capacitors before you try anything as this will nullify the possibility of electric shock.
Sai.
  • eagle338
    eagle338 Apr 30, 2010
    Sorry I had slight flare(Crohn's) yesterday so could not respond. Anyways you can get the part at radio shack or at most online stores. Yes if its a cap it will straiten itself. Note that LCD's have tuner board and they don't have a signal board(Small signal boards are exclusively found on Plasmas) . The logic is faulty caps take longer to charge thats why it will "set itself straight" after a while when it finally charges, that too it wont charge completely. The only thing is you have to find out which one of them are faulty so that we can check the specs and guide you to order the parts.
    Also since you said moving the set seems to fix the problem, I would like to look into a possible tuner failure as well. Please connect another input source such as a DVD player and see if the problem persists and let me know.
    Sai.
  • eagle338
    A power supply cannot cause the vertical colored lines problem. You can run a search on google if you want. This is usullay a main audio video board related problem or possible tuner related problem. I don't know whose advice you are following but its misleading you.
When started, why are vertical color bars showing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 26, 2015 | Samsung LN-T4053H 40 in. LCD Television
When The HDMI cables are connected, I use Directv, I have just recently started to have the picture come on and then start flickering and various color bars pop up on screen, then the screen will go black...
It is possible that the HDMI cable is defective. Did you try another cable?
It is also possible that the HDMI port on the TV is failing.
This can be determined by the process of elimination.
Jerry G.
Jun 06, 2008 | JVC Televison & Video
Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at www.partstore.com ,
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
Apr 06, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Vertical Color Lines with Sound
well I recently took my tv to a tv repair shop and they told me i had to replace the Y board and a Driver board. All in all it set me back $550.00
Aug 12, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Sony KDL 46V2500
This set does have a video problem. If it was bought locally, then, the retailer may have a 30 day return policy. If bought online or cannot be returned, then, contact Sony, for a service center in your location: http://eservice.sony.com/webrma/web/index.do Either way the set is to new to have a problem and you should get it resolved as soon as possible.
Aug 04, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Vertical flickering color lines instead of pictures
Take your set to a qualified tech you have a bad vertical ic or some cap around the vertical section is not filtering the voltage properly and your deflection yoke could also be bad.good luck.
Mar 16, 2007 | Sony PFM-42X1 Plasma TV
TV Bars
These are called vertical retrace lines. They are going to get worse untill you find the bad capacitor(s) or replace the vertical driver/output IC. Please, if you have not the solid state repair experience, get a pro to assist you in this repair as there are no user replaceable parts inside this set. Good Luck PLease do not forget to rate this thread.
Dec 11, 2006 | Curtis CM27002S 27" TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
