Question about GE Hotpoint Top-Freezer Refrigerator
Re; hotpoint refrigerator
My son jumped off the counter and since then the refrigerator fan has not stopped running and it is very loud and annoying. I just need some help on how to quiet it. I have tried to bang on it lightly but it doesn't work at all.
  • 109 Answers
Probably the blades are hitting something , slide the fridge out and inspect, as far as it running all the time, many fridges run a lot more often than you think. the fan being noisy is drawing your attention to it more now.
Posted on Mar 29, 2008
SOURCE:
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Apr 18, 2010 | Hotpoint HSS25GFP Side by Side...
Hotpoint refrigerator model # CTF16GKC.. a loud annoying buzzing noise recently started coming from below the fridge. What is this and what can be done to ELIMINATE it?
You could have a piece of paper hitting the condensor motor fan blade. Pull the machine out from the wall, unplug it and remove the fiber or metal panel at the back, bottom of the fridge. The fan will be on the right side. Check if for any debris that might be hitting the fan blades.
Mar 03, 2010 | Refrigerators
My fan in my freezer makes a humming sound
it;s best to replace the fan / or find why the noise . it will probably stop due to this problem. and you may loose food . noises generaly are the first clues . and like i'v said before . if you can hear it it's running . but if your cant it may have quit . . then not cool and food loss . **** / hope this helped mm / feed back pls .
Jan 16, 2010 | GE Hotpoint Top-Freezer Refrigerator
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint side by side has recently bugun making a lot of noise
Check for frost in the freezer compartment that may suggest a defrost problem which would cause it to run for extended times and make more noise. The other possibility is that if the fan is making a up and down type of noise, it will need a new fan in the freezer section due to a faulty bearing in the motor.
Oct 23, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
HOT POINT NOT COOLING WELL
if the condenser fan ( the one near the compressor) is not running and the compressor is running, then that's not good. try to lubricate the bushings of the fan and see if it would run. feel the blade if it turns smoothly. if it's sticcky, then there is your problem.
it should be running the same time as the compressor. if the compressor stops, the fan should stop too.
tnx 4using fixya,
drcool
Sep 26, 2008 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Refrigerator making loud noise and fan: help!
take raer panel off inside freezer and check there is no ice build up which is hitting the fan
Jul 18, 2008 | Hotpoint HTS16HBR Top Freezer Refrigerator
Under counter beverage cooler
It might be ice around the fan. Try defrosting it. This has been happening to mine, even through it is supposed to be 'frost free'
Jan 15, 2008 | Avanti 310SST Compact Refrigerator
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
