Question about Brother HL-5240 Laser Printer
We had a power outage last night and now every light on the printer is flashing. I have shut down everything, reconnected, uninstalled and reinstalled.
    Scholar:
  • 118 Answers
turn on/off, unplug, plug inWe had a power outage last night and now every - 2_bing.gif, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should reset printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Posted on Apr 29, 2010
I have an HP 7280 all in one. Worked great for a couple of years and now I have blinking lights and a code on the screen. The code is B0539F38 and sometimes it is 00729C8. I was able to reconnect it last...
You need to pull the right side panel off, remove the motherboard, pull the coin cell battery out for a couple of seconds, put it back in and back together. Your issue will be solved.
Jul 14, 2011 | Office Equipment & Supplies
I had a power outage. When I turned on the Dell it came on but said the DSL didnt connect so I shut down. From that point on, I only get the bliking amber light when i push to start up. All the other...
From what I am understanding you are having issues connection to the Internet after your power outage. If this is the case you would need to power cycle everything,
Start by shutting down the pc from the start menu.
Remove the power from your router and modem,
You will need to wait 30 seconds before you can plug the modem back in, once all lights appear on your modem replace the power to your router.
Once all the lights on the router appear...Power the pc on. This should resolve your issue.
Mar 30, 2011 | Dell Dimension 3000 PC Desktop
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Copier power outage while in operation caused paper jam and shut operation down. Service icon activated and will not go out.
Hello sir; Try to do a reset, open clamshell and remove top front cover, close clamshell and reconnect cable from cover to DC controller. turn on power and then short pins JP101 & JP102, the display will show out "F" release the short, then put everything back turn on the power.
Oct 20, 2009 | Canon PC-940 Black and White Copier
My Vip622 was down this morning, no power outage,
Unplug the unit from the mains for at least an hour, then plug it back in again and try to boot it up.
Good luck
Jun 19, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Power went out and back on; now printer won't print
I had the same problem after a resent power outage. Here's what fixed mine.
Turn the power switch off.
Wait a 15-20 seconds
While holding the button on the front panel down turn the power switch on.
After the drum light comes on release the button wait then press the button again.
Turn the machine off then back on again and you should be back in business.
To prevent the problem in the future if you are not using the printer turn it off and if the power goes off while printing get the printer turned off before the power comes back.
Oct 14, 2008 | Brother HL 1440 Laser Printer
Simpletech external simple drive model 96300-40001-001--flashing blue light
do you mean that you used this as a "Data" drive and do not have the data stored on your pc...
that is basically the same as having no backup... if it is important, store the data in more than one location.
it is possible that a power surge killed the usb adapter on your storage device.... you may be able to transplant the HDD onto a working adapter or USB->HDD bridge to get your data back
Aug 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Brother HL-5240 Laser Printer Logo
165 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
