Question about Danby 4.7 cu. ft. / 133 liter Upright Freezer DUF419W
I have had this in storage for several years only using it once. Now not working. When I turn the temp dial it will click but the motor will not click in. Does it need freeon perhaps and how do I put it in?
  • Danby Master
  • 43,501 Answers
The motor not clicking in is probably electrical internally in the motor...even with the system being sealed it is not a good thing for the motor to be sitting and not running at all for years...not to mention that there is also a relay and t-stat invoved there that may not be contacting properly to send the proper voltage to the motor.
In short, I do not believe that it is a refrigeration system problem, but an electrical problem somewhere...
Start at the power terminals of the compressor and work backwards till you find voltage...that will give you the culprit.
heatman101
Posted on May 01, 2010
Kenmore upright freezer only 3 years old running ,no clicking noise, no ice build up but won't completely freeze although set to 7 (lowest temp)
check door seals, also check vent direction, a dial or lever in fridge, it adjust how much air goes to fridge and freezer
May 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Lights are on but compressor won't work. Less than 2 years old.No display on temp control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back onand listen for a click from the compressor relay as the compressor tries tostart.
Is the compressor motor running.If no check starter/overloadrelay.
If the relay is ok the problem is the compressor which normally has a five year warranty.
Oct 16, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
Freezer Compressor Motor turns on and right back off
please check the following list,
1) check wheather the service wire is in good condition or not.
2) thermostart might have been off.
3) turn the refrigerator backword and see if is there any wire is disconnected/cut.
4) try changing the plug of the refrigerator.
if your problem is not fixed than please contact the service engineer. i'm sure that your stater had been blown.................. have a nice day:-)
May 14, 2009 | Frigidaire Freezers
We are trying to use our White Mountain Electric Ice Cream Maker for the first time. We put eveything together but when we turn it on the motor makes a buzzing type sound but we can not tell if the dasher...
I am intimately familiar with the 6 qt electric model, so let me give it a whirl. Our church uses 5 of these things to make 90 gallons of ice cream for the church ice cream social each summer, so they do hold up.
Your problem could be several things. The first thing I would do is to take the drive unit by itself and plug it in to the electrical outlet and see if it makes the same noise as when totally assembled. If it does, we'll deal with that in a minute. If it worked okay disconnected, then there's something binding in the dasher or the pivot piece in the bottom of the wood bucket. Once the mix is in the stainless canister and centered on the pivot bump, the dasher spindle that sticks out from the top of the canister lid fits in a certain way and then you must rotate the canister to get the lid to properly seat in the drive unit. Once all that is in place, it should clamp down properly on the bucket.
If the motor sounds the same as when assembled, then you could check to see if there's any lubricant in the gear housing(yellow metal thing the motor sits on). It's just a couple of screws to remove to take a peek. White mountain will get you a new motor assembly for a $10 shipping fee if you can produce a copy of the original sales receipt. the warranty is good for 5 years. Call 800-343-0065(old number but should stil be good).
One tip on making ice cream; when you get it going, don't cool the mixture too quickly as it makes the product really icy tasting and sort of "crunchy". If you get really crazy, monitor the temperature of the brine with an infrared temp gun or one of those thermometers with the remote probes. 8-12 degrees Fareinheit is ideal and that can be achieved by using a 5-1 ratio of ice to salt. If the temp gets below that, add some water or more ice. If the temp isn't getting down to 12 degrees, then add more salt. a cup of salt is usually good for about a 5 degree drop. Make sure you use the Morton Rock salt in the red box at the store. Water softener salt and regular table salt will either melt too slowly or too quickly for best results. Also make sure your ice has been at least partially crushed or it won't melt fast enough. Cubes need al ot of crushing, and even the ice from the convenience stor needs a wooden mallet taken to it before using. We had an old Alaskan ahand cranked ice crusher that worked perfectly. It was made back in the ealry 1900's. bought it on ebay for like $30. Our recipe comes out perfect after about 17-20 minutes of churning. the white mountain motor is strong enough that it will keep on spinning the product until it tuns it into butter, so a timer is critical for best results. Great ice crema making info on the web from the Universitry of Guelph in Ontario Canada.
Good luck
Max
Mar 30, 2009 | White Mountain Freezer F69206-X 6 quart...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
My freezer is about 2 years old, but has been in storage for about a year and a half. The green light comes on, and the motor is running, but it will not get cold or even cool.
Hi ndntwiggy,
Ngafm at your service
Your said,your freezer is about 2 years old, but has been in storage for about a year and a half.
And the green light comes on, and the motor is running, but it will not get cold or even cool.
When a compressor is not run for more than a year, or 2 years there is a possibility that the seals dried out from non use and the freon leaked out.
Compressors have oil in them that when run even once a month will lubricate the seals and keep them soft and moist! .
Just like in the older cars from the 1960's or 70's the air conditioners had to be run once a month even in the winter to keep the seals lubricated or they lost the freon!
Then they started to make the defroster turn the compressor on as to lubricate the seals every time it rained or snowed and you needed the defrosters and this serviced the compressor as in todays cars.!
So you need service to fix it and more than likely it's out of freon refrigerant .
Let me know your end results.
ngafm
Please give me a good rating for my accurate advice,
before you sign out of our site.
thank You ngafm
Sep 09, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezer not defrosting between cycles
Check the defrost timer for operation if your unit has one. Some Delfield models have solid state controls. If your system has a timer for the defrost you can open the timer cover and turn the dial in the direction indicated by the arrow until a time peg comes up to the time of day marker. You will hear a loud click and the compressor will shut off. Defrost should take place. The inner dial of the timer will have some indication as to how long in minutes the defrost should take. If the pointer does not move while in the defrost position the timer motor is bad. Turn the dial again so the copper pointer goes past the time of day marker and the compressor should restart. Replace the timer.
Jul 04, 2008 | Delfield 113.28 cu. ft. Commercial Freezer...
Danby 4.7 cu. ft. / 133 liter Upright Freezer DUF419W Logo
87 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Michael Van Der...
Michael Van Der...
Are you a Danby Freezer Expert? Answer questions, earn points and help others
