Question about Microsoft Windows XP Professional
Pc is not start up(screen does not display)
My pc does not start. when i start my pc only motherboard name and windows xp name dislplay.and stop and after then screen is blank.
  • Jubert Ledesma
    Jubert Ledesma May 11, 2010
    When did this start? What was the last thing that you were doing with the system before this happened? Did you install any new software or hardware before this issue? Did you move your computer to a new location?
    Problem Solver:
  • 18 Answers
Make sure Operating system is installed and you have selected the correct hard disk as first boot device from BIOS settings.
Posted on Apr 30, 2010
Motherboard no display problem. i clean my motherboard, and tried by changing CMOS battery also. but there is still NO DISLPLAY. please help me..
I would guess that your video adapter (possibly part of the motherboard) is not functioning. You can add an adapter in one of the available slots if you wish to keep that motherboard.
This is the most likely solution.
One thing you need to try before buying a new motherboard is to disconnect everything but the CPU, memory, and keyboard. Now start it and see if you get a display. If not, your motherboard is probably bad.
Jun 28, 2011 | Computers & Internet
Blue screen error appearing while installing Windows XP. I cant install windows xp. plz help me. I want to install windows xp.
format the drive in which you have XP before , then install a fresh copy of XP
then when XP's finished first of all Update your drivers first.
Find out what graphic/video card you have.
Start Menu > Run > Dxdiag > Go to the Display Tab >
It should say the Name of the Graphic/Video card.
After you find out the name just google the card and find the drivers.
Install it and see how it works. good luck do vote
Mar 31, 2011 | ASUS K8V-MX Motherboard
I just install windows 7 os but no dislplay where can I download an vga driver for Asus P5VD2-MX se
this motherboard is not on asus's list of windows seven supported motherboard, which doesn't mean it doesn't work. use this link to asus's download page: http://support.asus.com/download/download.aspx?SLanguage=en-us if you are using windows 7 32bit version , use the vista 32bit display driver . if your using the the 64bit win7 version, download and install the vista 64bit drivers.
Regards..
Jul 25, 2010 | ASUS P5VD2-MX SE Motherboard
My laptop screen has no display only black and then nothing
switch on the laptop...>press F8...>select last good known option. and check.... you can start with safe mode ..... if its not working reinstall the os.....
Oct 28, 2009 | ASUS Eee 4G Notebook
Display problem after xp splash screen
try to decrese the Resolution.
800 X 600
or
1024 X 768
plz rate this post.
Feb 09, 2009 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Boot problems!
Hi gcooper1873,
If your primary IDE has a copy of windows already on it, than that alone can cause the system to re-boot & go into a loop of re-starting. It is alway recommended to install windows fresh when a user replaces the motherboard with a new motherboard. The only execption to this rule is if your replacement board is an exact match of the motherboard. Plat it safe. If you have another IDE data cable replace your current data cable. See if the system restarts.
If you have data on the primary IDE & do not wish to loose the data from your old windows than you need to create a new partition within the IDE's free space. This should stop the system from restarting. You can leave both IDE drives connected for this. Load your Windows XP CD & boot to it.
If the system does not load the Win CD than manually restart the system & press the F8 key every two seconds as the system boots. You should get this screen:
High-light the CD-ROM with the windows CD in it & press enter.
Read the display from windows XP's screens. You want to create a partition within the free space of your primary IDE. Than you want to install windows onto that new partition. By doing this you will not loose any data from your old windows partition. (You'll be able to delete the old win partition later).
Install windows complete & install all of your motherboard drivers from the Gigabyte CD.
Turn on windows firewall for protection. Click on, Activate Windows & do so by phone. Its free.
Update window. (Suggestion, when updating windows look through the updates & find .Net framework 1.0) & install. Its prefered to install all .Net framework's in order. ( 1.0, 1.1, 1.1 hotfix, 2.0, 2.1 ECT). Windows will want to restart your system inbetween some of these. Do so. You will also notice you may have to click on your user ID to log into windows, this will go away after all .Net frameworks have been installed. Do not remove guest from within user accounts in control panel. Once windows updates are finished you can now copy the old partitions data folders to the new windows folders.
Suggested folder's to copy:
C:\Documents and Settings\ User name\Application Data\Microsoft\Address Book
C:\Documents and Settings\ User name\Desktop
C:\Documents and Settings\ User name\Favorites
C:\Documents and Settings\ User name\Local Settings\Identities
C:\Documents and Settings\ User name\My Documents
Data from any program you may have installed.
Now you need to get rid of the old partition with the old win XP on it.
Use windows disk management program.
Click the start button, click on run & type in " diskmgmt.msc " & press the enter key.
You'll need to change the old win partition to a different drive letter. Example: Your IDE drive had one drive letter assigned to it - C:\. Windows most likely kept the letter C:\ assigned to your old windows.
With disk management you can re-assign all your drive letters. Once your sure you have all your data copied over onto the new installation you can delete the old windows partition.
Which one of these motherboards is your's? Click the link below;
http://www.giga-byte.com/Search/Search_List.aspx?Keyword=GA-P31&SearchType=Spec
Good luck gcooper1873!
Any question? Post it here....
Mike
Oct 21, 2008 | Intel Motherboard
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
