Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Yellow Haze Thank you for the information but my Zenith is a LCD not DLP. Does that make any difference? Also how hard is it to fix? Can I repair it my self?
  • 59 Answers
If your model number is E44W46LCD Rear Projection , yes this will should fix your problem and you can do it yourself. Just be careful with the LCD cube that is beside you color filters, it is very fragile and hard to get.
Posted on Mar 24, 2008
There is like haze spot
LCD Panel White Spot Cleaning Technique - YouTube
? 4:13
https://www.youtube.com/watch?v=0OzjLMKFYk8
Jun 9, 2012 - Uploaded by joegingCA
Simple Technical procedure on how to remove a white spotproblem of an LCD Panel. ... Don't like this video? ... How to remove liquid spots from LCD screen - Duration: 5:16. ... Building a liquid crystal display (LCD) - Duration: 13:49. ... 2:18:17. Samsung/Mitsubishi/Toshiba DLP TV Repair - Black & White ...Missing: 170s4fb ‎haze
LCD TV - Problem with white glow seeping in from edges - MyBroadband
mybroadband.co.za/.../349324-LCD-TV-Problem-with-w...
MyBroadband
Jul 12, 2011 - 15 posts - ‎9 authors
Results 1 to 15 of 17 ... After googling it seems this is quite a common problem withLCD panels, though I .... Earlier this year I read that Philips have sold off their LCD TV... Yeah, something like that, unless demo stock is treated differently? ... bleeding from the edges as well as in the middle of the display.Missing: 170s4fb
How to Fix LCD Monitor Ghost images - MadeByMark.com
Jan 14, 2016 | Philips 170S4FB 17" LCD Monitor
Purple/white haze spot
Go to the Zenith repair site. This has been resolved in a lawsuit. Zenith will fix it free of charge through 7/1/2010. The shop just picked my up to replace the light engine free of charge. Call 1-800-228-1757, have your model number and serial number, and where you purchased it. Here's the neat thing-the question I asked is "have they fixed the problem with the light engine, or is it going to keep going bad?" If happens again (blue lines/spots) before 7/1/2010, they'll replace the TV with a new and different TV of equal value!
Jul 09, 2009 | Zenith E44W46LCD 44" Rear Projection...
I changed the LCD lamp, but there is still a yellow haze.
The yellow haze is the result of the blue polarizer burnt-in, you will find it sitting in front of the dlp chip.
Mar 20, 2009 | Zenith E44W46LCD 44" Rear Projection...
Replacement Filter for LCD TV
hey there yeah you are right your LCD is brunt out, to be honest with you I don't think they sale just the LCD chips you have to buy the OPTICAL BLOCK to fix this problem good luck.
Dec 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow haze
Hi...the yellow haze is probably the blue filter is burnt and needs replaced. This is very common in Zeniths. There are 3 color filters in the Zeniths blue (pinkish in color), green (grayish in color) and the red (it is red). The #1 problem in this TV is the blue filter is burnt and it is an easy fix. It could also be the LCD cube is bad. I would try the blue filter replacement first. It will probably do the trick.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow haze
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 23, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow Haze Center Screen
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Growing blue haze on our picture screen.
This is a bad problem with the light engine caused by overheating usually due to reduced airflow from dirty air filters.
My recommendation is to push your warranty company to replace this subpar model with a different one. There are too many instances of repaired models having a reoccurance of this same problem.
The blue line you are seeing is a product of one or two possibilities. The LCD panel which provides the blue imagery, which by the way is made by SONY Electronics, is defective. The LCD panel, in the optic engine (made by Ricoh) is basically loosing partial horizontal data, or the blue color filter has overheated and is becoming discolored, causing the loss of correct deflection through the optic prism. There are two ways to approach this. LG can offer some concessions and get you squared away, or provide the part, and you would be responsible for the service labor involved. Either way it can happen. The first thing I have to suggest to anyone purchasing a LCD or DLP projection TV is REMEMBER to keep an eye on the air intake filters. LG / Zenith products have one in the rear of the set, and 1 on the bottom of the unit. Reduced air flow through these units cause these "video deflection" issues. Overheating plainly affects these sets. I personally wouldn't own one, no matter who made it.
Jan 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith D60WLCD with blue haze over entire picture
throw the set away!the part required to repair the set is the optical engine.Zenith made alot of these sets with defective engine assemblies in wich the lcd filters burn,which cannot be replaced.The labor is also silly.Theunitrequires a complete teardown for replacment.You could buy a very nice new set for the repair bill
Feb 20, 2007 | Zenith D60WLCD 60" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
