Question about Bernina BERNETTE 65 Mechanical Sewing Machine
When I try to thread my needle, the arm doesn't even reach the hole in the needle. Everything operates fine, the self threader just doesn't come down far enough to feed the thread into the needle! Please Help
  • 1,116 Answers
Refer to your manual to be sure you have the needle in correctly.
Posted on Apr 29, 2010
Needle threader on 830 operates but will not let go of thread
1. Try a high quality thread; usually embroidery. Your thread sounds like Walmart. Look at it at a light and see if there is fuzz. That's bad thread.
If this doesn't work you have a threader that is bent out of shape causing it to hang on. You can attempt to adjust the threader with small pair of needle nose pliers, maybe even tweezers. Careful, it is fragile. The cost of replacement and a repairman will be over $ 50 so it is worth the try at home.
Oct 05, 2016 | Sewing Machines
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
There's nothing wrong with the Threader, it's just that the Threader doesn't reach the back of the Needle!
Usually you have to manually move the needle up and down until its height matches the threader height. Newer machines have an automatic needle stop that generally matches the threader but most older machines need to be manually manipulated.
HINT: If you do need to manually thread your needle, lick your index finger and then rub the back of the needle's eye. Your thread will literally "leap" through the eye! This works for hand-sewing needles too!
Feb 03, 2016 | Singer 8763 Curvy
Auto threader wont thread
Move the needle to the top.
Loosen the screw on the threader.
Use the threader as if you are using it. You will have to adjust it to the side and up or down. Move it so the threader is in the needle hole.
Tighten the needle.
If it still doesn't work you may need to replace the threader.
Apr 18, 2015 | Sewing Machines
The self threader won't catch the thread
make sure the needle is inserted correctly into the needle holder
if the needle threader has worked before then there could be something
wrong with the needle threader
here is a link for a manual
Dec 13, 2012 | SINGER 7470 Sewing Machine
How do you thread a pfaff 7570
If only we could put video links in here! But here goes:
Raise the presser foot;
Turn the hand wheel until the take-up lever (the hook bit that goes up and down, above the needle ) has reached its highest position;
Remove the small spool holder from the horizontal thread holder that is under the lid. Put thread reel onto spool, replace spool holder;
Pull thread behind first thread guide - it is the cream flat plastic bit towards the back - about 1" x 3/4" (i.e. the thread takes the first exit at the back);
Bring it down the left-hand long slot on the front of the machine, back up the right-hand slot, over the hook of the take-up lever, back down the right-hand slot and pass it from the side between the thread guide (silver metal bit just above the needle - looks a bit like curled metal). I found this last guide the most difficult to figure out - tried to get the thread into the curled bit - but you don't do that - it just slips in behind;
Thread goes through the eye of the needle. You can use the needle threader or not. Instructions for needle threader:
Lower sewing foot (makes more room and clamps the thread in the upper tension discs so it is less likely to keep spooling off while you are trying to thread);
Turn handwheel until the needle is in highest position;
Pull the needle threader straight down and then twist it to the front so the tiny hook on the threader goes through the eye of the needle;
Take thread under the larger metal hook on the left, put your thumb on it to stop it coming off, thread goes back towards the needle and under the small hook that is poking through the needle from the back;
Twist the needle threader towards the rear, releasing the thread carefully and allow the threader to move upwards. There should be a loop of thread left in the eye of the needle and you can now pull it all through to the back.
That sounds really complicated but I find the Pfaff needle threader works really well, unlike that of some other machines. I also have a Husqvarna Designer 1 whose needle threader works great, but the one on my friend's Designer SE is useless. Go figure!
Feb 02, 2010 | PfaFF Creative 7570
My auto thread component is not egaging the thread down to the needle.
Need more information. Is the auto thread component going down to the needle? Is
it missing the needle hole? If this is the problem, make sure that the needle position is in the correct position by pushing the needle position button. This will bring the needle to correct height for the thread to be inserted. I had a problem similar and it was because the needle was not in the correct position. When using the thread insertion press it slowly and watch to see where the insertion part is going.
Oct 29, 2009 | Brother CS-8150 Computerized Sewing...
Self threader won't work
the needle should be in the up position or the threader won't come down, still when it does, you have to get the thread right across the hole in the needle for it to catch,
another problem is that you bent or broke the center pin that pulls the thread through the needle,
the tip that comes to the needle has three parts, the two outer ones that wrap around the needle and the center pin that goes through the hole in the needle,
If this is bent you may be able to bend it back if broke you need to get it replaced
take a good magnifier and take a look at the center pin!
Hope this helps
Sep 06, 2009 | Singer 3116 Simple
How do I theard the needle on the 5050C singer machine?
does the machine have a needle threader? first if so, pull it down and put the thread behind the left side of the threader and loop the thread around toward the needle then go behind the finger of the threader hold the thread back against the needle and slightly pull upwards pull the threader forward and gently let go with the right hand of the thread and the needle will pull the thread through, second if the machine doesn't have a threader, the easiest way to thread a needle is to buy a needle threader, it is a device that you put through the eye of the needle and put the thread through its hole then just pull the threader back out and the needle is threaded.
Aug 22, 2009 | Sewing Machines
Threading & Use of Needle Threder
Threading as per image....make sure presser foot is up so top thread will properly engage in tension unit, make sure your thread is inserted in small guide on needle arm too. Your user guide should have a clear graphic of this process which is essentially the same for all machines.
As for the needle threader, once thru the last guide on the needle arm, raise needle to highest position, lower the needle threader so that the tiny hook engages the eye of the needle and place thread horizontally from L to R along the plastic arm so the tiny hook can grab thread, release threader and a small loop will form in needle, pull it clear and you are away !
If the tiny hook has been bent, a little judicious and gentle bending to re-align may be necessary, use a jewellers screwdriver or similar and please be very gentle
Feb 07, 2008 | Janome Jem Gold 660 Sewing Machine
Bernina BERNETTE 65 Mechanical Sewing Machine Logo
267 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
