Question about Ricoh Aficio 1035 Copier
Copies run through the feeder have black line on them, copies on glass & faxes are okay
  • 1,110 Answers
Clean the ADF scanner glass. This is the small strip of glass that is just to the left of the large glass. Normally there is a label on the machine right by this glass that instructs you to clean this strip of glass whenever streaks appear when using the ADF or Automatic Document Feeder. Sometimes toner/dirt gets stuck on this strip of glass so clean it well using a soft cloth with some glass cleaner.
Good Luck and Thank You for using Fixya
Posted on Apr 29, 2010
  • 410 Answers
You need to lift the document feeder up and look even closer. There is usually some "white-out" or a smudge on the thin glass slot that reads the documents as they go by.
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Black line running down the middle of the page when faxing or copying using automatic feed tray. If I lift lid and copy no line. Receiving fax not line?
Generally this problem is due to the the glass under the lid being dirty. Some combo units have 2 scanning areas, the large one you are using to copy ans a small one it runs the faxes through. I suggest you clean any and all glass you can find on the machine and give it another go.
May 04, 2011 | Brother Office Equipment & Supplies
We have a black line down the center of all copies...
If the problem only happens on copies or sent faxes then no it is not your drum. There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on
May 20, 2010 | Office Equipment & Supplies
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
I have an HP J6480 printer, Fax copier, when I fax or copy a black line is down the center of the sheet. I replaced the toner. How do I fix it?
There is something stuck on the scanner glass. To test for this problem try making a copy by laying your original on the glass and making your copy, not running it through the feeder. If it copies fine from the glass it is definately something in the feeder/scanner glass. Just clean it with a soft cloth and some glass cleaner. You should be lookig for a thin strip of glass to the left of the large glass. Or you might have to open up the feeder unit and find it there.
Oct 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
I have a black streak all on one side when i copy ?
If it is just when you copy and not when you print then it is a cleaning issue. Toner cartridge would cause the line to appear on copies, printouts and faxes. There is a piece of glass inside the auto document feeder that is probably dirty. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Black lines
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Black lines on copies when run thru fax feeder
Ricoh Aficio 1035 Copier Logo
282 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
