Question about Thetford Porta Potti
Porta potti 245 flush dont work
Porta potti model 245 flush dont work. manuel pump works but nou water comes into the ring to flush
jyackle5
  • 8197 Answers
SOURCE: Cleaning a thetford porta potti
You can get the manual here.
http://www.thetford.com/Home/Products/PortableToilets/PortaPotti135Marine/tabid/96/Default.aspx
Good Luck and Please Rate FixYa!
Posted on Jan 09, 2009
SOURCE: Need instructions on how to empty Porta Potti 165
Your lucky day I found the answer to your problem. I also need some info and checked out the net.
Just go to www.thetford.com
You should be able to find a download for your potty as I did for mine!
Hope this helps!
Posted on May 15, 2009
  • 61 Answers
SOURCE: Flushing knob on a C2 Theford cassette porta potti hard to turn
Hi! Spray blade which closes holding tank with silicone spray. Make sure spray goes under lip of sealing ring. Also spray around holding tank actuator knob allowing to penetrate underneath to shaft. Don't use a silicone grease as this will gum up the works. If you can't get hold of a light silicone spray try using household type silicone polish intended for furniture. Wipe off any surplus as only thin film required.
John Long
Posted on Jun 11, 2009
  • 61 Answers
SOURCE: need to empty the porta potti 335
Go to www.thetford.com Click Customer Support then click Product Manuals. Choose your manual and download file.
Posted on Jun 13, 2009
SOURCE: How to get to the pump in a porta potti 32
Have resolved the issue. Many thanks
Posted on Oct 18, 2009
Thetford porta potti not flushing. Can anybody advise me what i can do to correct this.
Check the bellows has no cracks and that the top rinse tank is full of water & rinse solution.
Apr 13, 2014 | Thetford Porta Potti
Manual for 1992 Fiamma porta potti
Sorry, don't mean to be pedantic but Fiamma is just a potti not a Thetford Porta Potti. (TM)
I only have experience with Thetford.
Nov 07, 2011 | Thetford Porta Potti
I just bought a used Sportsmobile built in 2002. The Porta Potti was never used butI need a users manual to figure out how to use and maintain it. I can't find a model or serial number. It just says...
According to the Sportsmobile custom website, the porta potti you have is called a Thetford Electric flush porta potti. There is only one electric flush made by Thetford, so a model number is not necessary to locate instructions or a manual that shows maintenance and use ect.
Here is a link to the manual, parts list and usage instructions for your Porta Potti. When the page opens, click on the link on the top right hand side that says "manual" to download a PDF version to save to your computer.
I hope this helps? If you are happy with my solution, please rate it on Fixya! Thanks!
http://www.thetford.com/HOME/PARTS/PortableToilets/PortaPottiElectricand585PartsNEW/tabid/656/Default.aspx
May 31, 2011 | Thetford Porta Potti
Where is the water pump on a Thetford C 402 C/X located and how do I get to it.......thankyou.....Mal Hughes Western Australia
hi the water from the flush holding tank is not getting through to the pump on my c402 thetford toilet . i have tried putting water in from the glass indicator tube and the the flush works . anyone got any idea what the problem might be thanks
Oct 12, 2010 | Thetford Porta Potti
Hi, have a built in thetford toilet in my caravan. The pump has stopped working. How do I check and remove the pump if required? Thanks Rosco
Don't send money. Just go to thetford.com and download info.
Some tips - if seal is old and breaking up make sure you recover all the bits which have fallen into the flush water tank. If new o-ring seal not available use outdoor silicone sealant and allow to set for 48 hours before adding anything other than a small amount of water to test flush action. Electric circuit includes a fuse and microswitch which are both contained within the flush water tank but you are unlikely to have problems with these items.
Nov 04, 2009 | Thetford Porta Potti
Toilet won't flush. New pump fitted fuses ok.
Thetford Model Cass C2 L TC WHI - Toilet won't flush. There is power to the switch and flasher. Any ideas?
Jul 30, 2009 | Thetford Porta Potti
John Long
Jun 07, 2009 | Thetford Porta Potti
Im trying to find the wiring am for a thetford C2 porto potti
Go to www.thetford.com.
Click Customer Support then Product manuals and download manual in PDF format.
Wiring of C2 has fuse, safety switch, flush switch and flush pump in series. If fuse is blown you probably need to replace pump. Instructions come with replacement pump.
Jun 04, 2009 | Thetford Porta Potti
I have a Thetford Porta Potti 465 electric. The
Good news , you can go to ;
www.thetford.com/products/toilets/
Click on " Support " , and you should get the help you need .
Good luck !
Alec .
Sep 05, 2017 | Thetford Porta Potti
Thetford Porta Potti  Logo
218 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Patricia Cross
Level 1 Expert
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
stynger007
Level 1 Expert
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
