Question about Microsoft Windows Vista Home Basic for PC
-3-y=8 y-2z=5 x-2y+z--7 what is the soultion set?
How to solve 17-4z+2z=13
You are solving for "z". First, bracket the "z" values ad combine them to get this:
17 - (4z+2z) = 13.
This breaks down to:
17 - 6z = 13
Now, subtract 17 from both sides of the equation to get the "z" value isolated and the result is:
-6z = -4 (13-17= -4)
Since both sides are negative, you can drop the signs and get this:
6z = 4
To get the value of "z", divide both sides by 6 and the result is
z = 4/6
Simplify the fraction to z = 2/3.
Jan 26, 2016 | Office Equipment & Supplies
Why would Vinotemp (VT-21TEDS-2Z) winecooler just stop working?
Could be any number of reasons. If it's had problems with setting temperature, suspect the thermostat first, Failing that, check through the power circuit from mains in to compressor.
Apr 28, 2014 | Refrigerators
Torque specifications for toyota forklift 2Z engine
I AM LOOKING FOR CONROD BOLT TORQUE SETTING FOR A TOYOTA 2Z FORKLIFT
Jun 27, 2013 | Cars & Trucks
3 + 5 + 4 = 71 3 + 5 + 3 = 41 5 + 4 + 6 = 43 2 + 7 + 3 = 31 6 + 7 + 3 = ?
Soultion: False
unfortunately as an equation that is false, and is not possible
May 02, 2011 | Mathsoft StudyWorks! Mathematics Deluxe...
4x-y-2z=-7 -4x+8y+5z=46 8x-3y+z=13
Type solve(exp1 and exp2 and exp3, {x,y,z})
See cap images
Dec 15, 2010 | Texas Instruments TI-89 Calculator
Sir i have window 7 installed in my pc. but my pc is not installing the scanner in window 7 instead i have original dirver cd for scanner which works well in window xp. tel me the soultion
The version of driver is citical - if the scanner has Win7 drivers available use those, if not then it's not supported. If you have Pro or Ultimate you could try running setup with compatability mode.
Aug 06, 2010 | Computers & Internet
Vinotemp Dual Unit Not Working
You may have to replace the control board on the unit. You can order parts from Vintotemp @ 800-777-8466
Jul 04, 2009 | VinoTemp Refrigerators
Solving matrix
Go to your matrix button and enter a "3x4" matrix.
Then enter it as follows:
-3 4 5 7
4 3 2 9
-5 5 3 -10
Then exit out and go to "2nd->matrix->math->rref(". Then press enter.
Your screen should look like this:
rref(
Then go to matrix and select your 3x4 matrix, press enter and close it with a parathesis. Your screen should look like this:
rref([A])
Press enter and the screen should say this:
1 0 0 2
0 1 0 -3
0 0 1 5
So,
x=3
y=-3
z=5
Hope this cleared up the confusion!
SJ_Sharks
Mar 03, 2009 | Texas Instruments TI-84 Plus Calculator
Algebra college
Consider the following system of 3 equations in 3 unknowns:
x + y = 2
2x + 3y + z = 4
x + 2y + 2z = 6Our goal is to transform this system into an equivalent system from which it is easy to find the solutions. We now do this step by step.
  • Subtract 2*(Row1) from Row2 and place the result in the second row; subtract Row1 from Row2 and place in the third row. Leave Row1 as is.
x + y = 2
y + z = 0
y + 2z = 4
  • Subtract Row2 from Row3, and place the result in row3. Leave Row1 and Row2 as they are.
    x + y = 2
    y + z = 0
    z = 4 From the last form of the system we can deduce the following unique solution to the system:
z = 4, y = -4, and x = 2-(-4) = 6Equivalently, we say that the unique solution to this system is (x, y, z) = (6, -4, 4).
Sep 17, 2008 | Belkin (F5D7230-4) Router (587009)
Microsoft Windows Vista Home Basic for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
