Question about Apple iPhone Smartphone
Dial out cannot dial out from my iphone.when i touch the green phone button go back the normal position
  • Anonymous Oct 14, 2008
    I have the same problem
  • 4 Answers
Seems like a software problem. I can suggest restoring the iphone firmware.
Posted on Mar 25, 2008
I took a picture with my iphone and I can't get the green screen off?
Force the phone to shut down and reboot.. Hold the home button and power button at the same time for at least 10 seconds wait for a few then turn it back on as normal.
Nov 22, 2013 | Apple iPhone 3G
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Can i turn off voicemail
To turn off your voice mail automatically, turn off your phone and turn it back on after 5 minutes, then you enter ##002# and press the green/dial button, it will automatically deactivate the voice mail from the phone. Then test it by dialing the number of the phone from another phone to see if it will go to the voice mail or it will ring normally. I trust it will ring normally after doing the ##002# and dial voice mail reset.
Hope this helped you. Thanks for using fixya.
Jan 26, 2011 | Samsung SGH-G600 Cellular Phone
What is the code to program a Merlin BIS-10 to have only (1) incoming line. I have a 10 button phone and it thinks there are (5) incoming lines?
Enter admin mode:
Slide switch on left (T/P) down to the "P" position.
press the intercom button above TRANSFER
dial the 2 digit extension number you want to modify
Touch the buttons to add/remove the lines.
Green light on means line is active
Green light off means line is not active
Mar 24, 2010 | Avaya Merlin BIS 10 Corded Phone...
I just replace my touch screen and lcd the phone will not do anything. I have tried the two buttons
By holding the power off button and the menu button, it resets the iPhone and everything will go back to normal. Mine was stuck at the shutdown screen but I tried this trick and it worked.
Mar 05, 2010 | Apple iPhone Smartphone
My iphones touch screen is not working but the menu but is.....it kinda also got a ****....... thnx...
Sep 25, 2009 | Apple iPhone Smartphone
Speed dialing problem
you should use the number like 3 and the green button which you use to pick up the phone
Jun 28, 2009 | Samsung S8300 Ultra Touch platinium-red...
White screen with lines
It appears to be a sleep state that the phone enters into.
How, I do not know. If your iphone/ipod touch screen is
pure white...here's a simple fix, gaurantee to work.
Hold the power button, and the home button, and the apple
logo will appear....release both buttons, phone will resume back to
normal.
Jun 06, 2009 | Apple iPod touch
I need to find out how to return to a normal tone
There should be a button on the phone labeled 'tt/pulse'. The button should be moved to the 'tt-touch tone' position.
Apr 16, 2009 | Lands Phones
Cant dial out manually
If you happen to install Kate from cydia. Uninstall it! that causes the problem.
Sep 29, 2008 | Apple iPhone 3G
Apple iPhone Smartphone Logo
49 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
