Question about Garmin eTrex Summit GPS Receiver
Sight n go as described on page 16
When I go to the options menu on the Pointer Page the Sight N Go option is not hight lighted and can not be activated, How do I overcome this problem Thanks
  • marshsly Nov 01, 2008
    can't activat sight and go on the map page
Make sure you are outside with a good bunch of satellite and it should work.
If not go to the compass page and restore defaults.
Calibrate your compass if you have one,
Posted on Nov 02, 2008
  • 5 Answers
Also make sure the compas is turned on.
Press and hold QUIT/PAGE to turn off or on.
There is an icon telling when turned on
Posted on Jan 25, 2009
SOURCE:
Instructions to mount scope
PDF]OWNER'S MANUAL - Crosman
www.crosman.com/pdf/manuals/M4-177-515.pdf
Translate this page There are two different rear sight options for the M4-177 depending on which model you purchase.) Option 1- ... the airgun in any way inconsistent with this manual may make your ... Adjust the rings on your scope to match the measurements of the top rail. ... Toattach the sling at both ends push the sewn webbing loop end.
Crosman M4-177 Multi-pump .177 Pellet Air Rifle Table Top ...
? 24:29
https://www.youtube.com/watch?v=s_0grKCOmX0
May 18, 2012 - Uploaded by Replica Airguns
ReplicaAirguns.com - Crosman M4-177 Pellet-BB Multi-pump Air Rifle ... -Single shot - bolt action with manual advance magazine.... I particularly like the removable iron sights and full rail formounting a scope or red dot sight.
Crosman M4-177: Installing and Adjusting the Sights ...
? 8:38
https://www.youtube.com/watch?v=x8XKOmb41QA
Aug 28, 2012 - Uploaded by Crosman
A detailed look at installing and adjusting the sights for the M4-177 and sighting ... Crosman MK-177 Pellet-BB Multi-pump Air Rifle Table Top ...
Crosman M4-177 shooting rev
Dec 20, 2015 | Crosman M4-177 Air Rifle
Google homepage loadsthen says that any other sight is cant be displayed
this might be because google is your homepage and you need to type in a search
run your antivirus program
right click in your bottom toolbar select task manager applications if you see something running that shouldnot be be select end now
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com, google.com)or your preferred browser
hope this helps
Nov 24, 2011 | Sylvania G-Netbook
Please describe your how can i use in legal page setting in printer sharp ar5516 problem
go to start -> devices and printer -> select the printer -> right click on it -> select printer properties
-> choose page set up -> if you see "page set up option on it" click on it and choose the paper size
legal or anything that you want
and if you dont see page setup option where I have shown, do search for such option in
printer properties
another option is that....
when you give print from word,excel anythig you get windows to select printer, choose the printer
go to properties and all those same steps,
or
in word,excel or other application there is page setup option in file menu (in office 2007 and 10)
if is on "page layout" option.
Mar 14, 2011 | Office Equipment & Supplies
Change text size while reading an internet sight with a windows 7 laptop
Enter on a page that has text. Then from the top-right menu, click on Page menu and watch down to the Text Size. You have some options like Smallest, smaller, medium, large, very large. Choose the desired.
Nov 02, 2010 | HP Pavilion dv6326us Laptop
Just want to secure my internet sight
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here
for step by step instructions
Jan 06, 2010 | Arris SURFboard SBG900 Wireless Router...
I just purchased a Garmin Etrex Summit GPS receiver. The function that I most need is the Sight 'N Go, but when I access the pointer page options list the Sight 'N Go option is 'greyed out', although the...
It is greyed out when the electronic compass is off. Switch it on by holding down the top right button for 2 seconds. A confirmation message flashes up on the screen.
Apr 19, 2009 | Garmin eTrex Legend GPS Receiver
Downloading from web sight screen turns dark gray and closes!!
What OS are u using? Try Internet Option-security tab and lower the security, & also enable user to access sites that do not have any rating, in Advanced tab select SSL 2.0, SSL 3.0, TSL 1.0, enable native XMLHTTP support, allow active content to run files in my computer, enable Java Script & Java Logging & Java Console, use Passive(FTP) use HTTP 1.1, Privacy settings at LOW, in CONTENT tab enable all the sliders to the (extreme-right) & set a password(simple, only for u) & in general tab selct user to see sites that have no rating. This should solve this.....sodeep
Mar 24, 2009 | Microsoft Windows Vista Home Basic Edition
How do i use the continuous shot mode on my camera?
Page 18 & 22 of the PDF manual shows where it is located on the menu and how to get there.
Page 23 states the CAMERA selects which of the 16 shots is best.
Page 48 describes Continuous mode under SPORTS.
Page 103 of the manual shows how to do it. (p91 of the printed manual)
http://www.nikonusa.com/pdf/manuals/noprint/S550_ennoprint.pdf
NOTE - the PDF page does not correlate to the ACTUAL page numbers.
Type continuous in the pdf search and keep selecting NEXT until you reach the pages I have noted, or Jump directly to the page by typing it in the PAGE field.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Compass on Rino530 "Sight and Go" problem
I would make sure the compass is turned on. When it is off navigation tools are hard to use.
Nov 08, 2008 | Garmin Rino 530 GPS Receiver
Print coming out too small to read
that's a function of the print settings in your application. most likely there was a scaling check box and it was applied to the whole document. good thing it 's most likely a global issue.
if you can do this, great..otherwise, you may want a shared screen e housecall from our team. send me an email from my profile contact information.
Mar 10, 2008 | HP PSC 1410v Printer
Open Questions:
See all Garmin eTrex Summit GPS Receiver Questions
Garmin eTrex Summit GPS Receiver Logo
766 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
