Question about Nokia 1600 Cellular Phone
Phone key 3number not working - Nokia 1600 Cellular Phone
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
It might be that your keypad board has been damaged or the chip has been damaged. You will need to get it repaired.
Posted on Apr 30, 2010
Where can I find Serial number of Dewalt hummer drill
Most hammer drills on battery from brand Dewalt have its serial number in one of the yellow shell parts its a build code of the shells only under the battery holder also the year of build date stands there too it have the same function, I myself have long wondered too, because some Dewalt tools have a real serialnumber is it not fully clear why there is sometimes not and sometimes a full number to find, i have asked that also on Stanley Dewalt in Belgium. Ser 030942 on this picture but i know maybe you see a clear yellow line in black on the information sticker where you think there should be placed the number and they forget you will find no real number but always you can use the 2 3number code with year of build in one of both shells under batteryholder .
Jan 27, 2016 | Dewalt Drills
Tip
How to repair keypad problem in China Mobile
First we need to know china phone keypad connected with PCB how way
(A) Direct on PCB
(B) Flex System (flex cable direct soldering pcb to keypad panel)
© Flex and socket system include (flex one side soldering with key panel other side connect to pcb with socket)
(D) only Socket System (here have 2 socket, 1 with key panel others with pcb)
Keypad problem have various type
1. All key not work.
2. some key work and some other not work.
3. sometimes work and sometimes not work.
1. All key not work
china phone all key not work for this type of problem
(A) though its touch screen phone, first try to disconnect touch panel line from phone pcb or display flex (4 line)
(B) though not solve and keypad direct on pcb first you try to good clean full pcb with cleaner.
© though not solve now you try to format/flash your phone because some time key problem come from software problem.
(D) though still not solve now you check must be CPU. 95% china phone keypad directly going in cpu. and other 5% first going to resistor or capacitor near the cpu or keypad than going to cpu. so now first check them than you can try to re-hot, re-soldering or changing cpu.
(E) though its flex or socket system, first check GND connection continuslay pcb to key panel. next check full flex or socket all line going continuously pcb to key panel or not. also sometimes flex or socket shorted with other line or gnd so check also them.
(F) Also you can check all key anyone is short 2 line.
(G) sometimes keypad line broken from cpu pin on pcb to key panel, so check them.
2. Some key work and some other not work
Some key work and some other is not work for this type of problem
(A) maximum time this problem we face for flex or socket system keypad. so check flex cable and socket all line any line is broken or not and though need change them. and check all key connection on key panel.
(B) though its direact on pcb, some of key line broken internaly. and maximum china phone have alternative test point near every key or with other key on keypad. so check them with multimeter and though need connect to not work key with near testpoint or other working key.
© common problem is keypad metal ball (which is short 2 line on key when we press) sometimes its damage for phone water damage or over key voltage, so clean them or change.
(D) also try to check line continuously from cpu to not working key.
this problem come from this defect
(A) flex or socket system keypad any line is bad soldering or do lose contact. check them and
re-soldering or keep there line join with extra ware.
(B) for cpu bad soldering or cpu pin is broken. so re-hot or re-ball cpu.
on Jan 06, 2010 | Cell Phones
Service engine light flashes car has no power going up hills exc. Oil is on the spark plug they say it's a 3number 3 misfire in a Subaru forester xp all wheel drive limited edition 2009 model?
Cam seals under cam cover if it is on the ceramic part of the plug, if it is on the gap where the spark takes place it may be head gasket.
Jan 26, 2016 | Subaru Cars & Trucks
Can i fix my toch screen on my zte warp it wont work
Hey james perform a reset on the phone or contact zte to find some help. Ill help u with the reset,
Power off the phone--Press and hold Vol+ key and Power key simultaneously until several blue sentences appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.---Use Vol+ key and Vol- key to move the cursor to "wipe data/factory reset" and press camera key to confirm it.-----There are many words "No" and one sentence "Yes -- delete all user data". Use Vol+ key and Vol- key to move the cursor to "Yes -- delete all user data". Press camera key to confim it.---The phone will finish the reseting by itselft after about 10 seconds later and then the cursor will be on "reboot system now" and press camera key to confirm it. The phone will reboot automatically. and it should fix the problem. N hey the only problem is u will lose all the data on ur phone. So take off ur SD card before u reset the phone.
Apr 10, 2013 | ZTE Cell Phones
My sony ericsson w705 button does not working....jz number key and call key work only..please help.
Same problem was with mine phone.
The problem is that your flex cable (aka "patti") is damaged due to its to and fro motion while sliding the phone.
flex cable is a flexible cable that connects everything in the front part of the phone (3g camera, control keys and screen) to the motherboard in back part of the phone. Your number keys are working because they are present in the back part of the phone and are not connected through flex cable
Feb 15, 2011 | Sony Ericsson Walkman W705 Cell Phone
My problem is that when am formating my mobile.password 12345 is not taking showing wrong
try 00000 mate it will work.
if above code is not working then provide us your imei no we will send you master code for your mobile.
there is one alternate method method which dose'nt requires any password. just follow the step below.
step 1. switch off your phone.
step 2. now press these three button at the same time.
(no1.*key
no2. green dialing key
no3. 3number key)
step3. switch on your phone while pressing these keys.
a message like formatting will appear on screen(in some mobile the message not come up but do'nt warry keep pressing.
now you are done.
Feb 10, 2011 | Nokia 6600
Need a puk code as my phone as been blocked and will only let me type in 3number on network 3
you need a puk code Your sim has been blocked open the sim's cards read the number (puk code) enter in mobile then use it as before.if problem not solve then tell me again
Jun 04, 2010 | Cell Phones
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
Krz K1
check well all the keys. it might one or more key/s that clug. thanks
Feb 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Keys wont work
send it back under warrantee. I had the same problem and let them fix it. They'll have a new phone to you in 2 days and they'll save your contacts and put them on your new phone. Let me know how it works out.
Cindy
Jan 30, 2008 | Motorola Mobility RAZR V3
Nokia 1600 Cellular Phone Logo
32 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
