SOURCE: MY 1998 CADILLAC DEVILLE REAR WONT RISE
arnott.com sells replacement shocks, take one of your orginal springs and go to a spring frabrication shop they should be able to fabricate a new spring for you with a 2 to 4 inch lift
SOURCE: 1998 cadillac deville
try taking off your fuse panel cover, there should be a reset button in there.
SOURCE: How to close the trunk of a Cadillac Deville 1994
I'm sure you have cked the fuses so take a look at the motor assembly at the trunk latch to see if you can dis connect it. Better yet, first tap the motor a few times and make sure it is tightly mounted. Loosen it and retighten the bolts holding it. Sometimes that will relieve and bind the mechanism may be in. Keep your fingrts clear of any mechanism. You shoul be able to hear any movement. good luck.
SOURCE: AC BLOWER MOTOR GETS HOT THEN TURN OFF.
I HAVE A 1998 CADILLAC DEVILLE,THE AC BLOWER MOTOR GETS HOT AND TURN OFF AND WONT TURN BACK ON UNTIL IT COOL OFF, WHAT IS THIS PROBLEM?
SOURCE: 1998 cadillac deville fans not coming on starts
If your fans are not coming on then your engine is not receiving the signal that it is overheating. This can be caused by bad fans (unlikely they are both out) a bad relay, or coolant temperature sensor. I would start by checking or replacing the temperature sensor as it can become corroded which is what the PCM uses to turn the fans on. Many vehicles use two sensors, one for the gauge and the other for the ECU, make sure you check/replace the right one. It should be a cheaper part and if you are unsure then match the new one with its location; it should be on the intake manifold or near it, generally with one or two wires. I think you will find your problem as they are common failed parts.
