Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Craftsman DLT 3000 riding mower started and my son made on pass in the yard, and the mower made a loud bang like a back fire, smoke was coming out from around the motor and now it will not start.
protek480
  • 1714 Answers
SOURCE: craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Replace the gas cap. Over pressure in gas tank
Posted on Jul 29, 2009
  • 582 Answers
SOURCE: Engine worked fine last week and for 3 minutes
IF THE ENGINE STILL TURNS OVER YOU MAY BE ONE OF THE LUCKY ONES ON THE OHV ENGINES PULL THE VALVE COVERS AND SEE IF ALL THE TAPPET RODS ARE THERE IF NOT THIS COULD BE WHAT IS BOUNCING AROUND INSIDE
WORST CASE IF ENGINE WILL NOT TURN OVER THE CONNECTING ROD TO THE PISTON COULD BE BROKEN
Posted on Aug 10, 2009
  • 420 Answers
SOURCE: Have a Yard Machine riding mower with 21hp Briggs
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Posted on Jun 04, 2010
  • 21 Answers
SOURCE: replaced coil motor starts and runs at an idle and
could be air cleaner clogged and/or crankcase ventilation
breather or tube to air cleaner frame work clogged
Posted on Sep 26, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a craftsman 48" mower with a 24hp B&S
Sears obviously does not do much engine maint. The float level is a tad high (I doubt it but possible) or... there is debris in the float needle (probably) Take off the float bowl and then clean the needle and seat area. You might have to remove the float to do this. Shut off the fuel supply of course! Remove the main fuel line from the carb and spray carb cleaner UP into the float needle area to back flush out any debris through the fuel manifold / main fuel supply connection.
Try doing the above first and if you still have the same problem respond PLEASE with your engine type model series number that will be similar in layout as the one above your text.
44K777-0027-E1 (Example only no spaces either)
FYI if you do a float level adjustment... you bend the tab on the float where the float needle connects. Fuel flow should shut off just as the float is level. You bend the float needle tab in SMALL increments only.
Let me know how it goes please.
Thanks for choosing FixYa,
Kelly
Posted on Jun 29, 2011
My Craftsman DLT 3000 Riding Lawnmower will not go into gear.Could something have come loose? a spring orwire to the mower?
At the rear of the mower at the very back is a transmission disingauge lever, it may be set, this lever is so u can easily push the mower when it is not running...!
Oct 26, 2014 | Garden
I have a DLT 3000 mower every time I let off the clutch it goes dead either in gear or out....HELP
With out more information it sounds like one of the safety switches is faulty -most likley the one under the clutch pedal .To test this locate and unplug the ignition wire coming from the engine to the wiring harness the engine should keep going -- you will need to plug it back in to stop the engine.If this works then repair or replace the faulty switch.
I hope this helps
Andrew A
Apr 14, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
DLT 3000 Intek 18.5 Carb Float Stuck?
If it starts cold and runs for 10 min then it sounds like the fuel cap is not venting properly, try runnin engine with fuel cap loose and see if it dies. 9 times out of 10 the fuel cap is the culprit. Let me know
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
357 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
