Question about Panasonic PT-47WX49 47" Rear Projection Television
Tv turned off
Hi, no there is no power at all since it turned off. I found one fuse and it looked fine.
  • 2 more comments
  • misg4420 Mar 27, 2008
    Hi, I got the tv to work again lol. I was looking at it and noticed how bent the cord was so I started bending the cord near where it plugs into the wall and when I pushed the power button the tv came on. This must mean that I need a new cord. Thanks for all your ideas and suggestions. I will definately contact you with any further problems.
  • jasonkaufman Apr 15, 2008
    PT-47WX49 will not power back on. If I unplugg it from the wall and plug it back in it will turn on for about 3 to 5 seconds then right back off again. I'm wondering if it is a fuse but I have no idea where the fuse(s) are located. Help... anyone.... please....
  • Anonymous May 28, 2008
    my Panasonic PT 47wx49 turned off and will not turn on. If I unplug it and plug back in it will stay on for about 3 seconds and then goes off. Any suggestions?
    My Panasonic 47WX49 turned off and will not turn back on. If I unplug it and plug it back in it will stay on for about 3 seconds and then goes off. Any suggestions?
  • Panasonic Master
  • 8,617 Answers
Its more than likely something in the standby power supply in order to be completely dead. I would suggest getting the service manual , and if you are wanting to repair it yourself. you can get free support to help you diagnose and repair the set for free when you purchase the manual from this link. They email the manuals and provide free support to enable you to figure out whats causing the problem and help by locating parts. Its a good service cause they have good service manuals and good support techs,
http://servicemanuals.vstore.ca/
Posted on Mar 24, 2008
Nissan Xterra Brake Light Fuse Location
Hi, you need to test if the power is coming to the plug for rear brake light. If the power is not there that is your first problems. Also may have earth wire problem.
Jul 20, 2013 | Nissan Xterra Cars & Trucks
TV will not turn on, 3.15amp fuse keeps blowing on power board
I have an ln40b630n1fxa and my fuses keep going out as well i took it all apart and seen nothing blown. What would be my next step
Nov 06, 2012 | Samsung LN40B630 40 in. LCD TV
Hi, My TV has been turning off by itself and
Good day!!!!
If your TV turn ON/OFF itself without sounds..The possible problems are voltage drop on power supply,overheat/overload,loose/cold solder of power supply or bad T-con board..
If you already inspected all capacitors on the power supply and all looks fine but it doesn't mean that your power supply board works fine because sometimes bad capacitors not look like bulged or looks fine visually but the value change its either lower/higher capacitance value.In that case you need to use capacitance meter to find bad caps..But before we do that,I have a procedure to minimize/eliminate troubleshooting.In this procedure you need a multimeter tester to perform voltage data check..
In this procedure we can determine where the fault came from..
This are the steps:
  1. Open the back cover.
  2. Look at the power supply board (it is usually connected directly to power cord).
3. Find the 3 long connectors near the aluminum heat sink.Those connectors having voltage marks on each pins so you can easily determine where did you get the voltage..
4. Point the black test probe to GND (ground) and the other probe (red) to 5vdc,12vdc/15vdc,24vdc..Let me know if you find any voltage drop or voltage lost..
5. If all voltages are works fine..The possible problem is on T-con/logic board or main board..But in that case the common problems is on T-con board I found it online $34..
Hope it helps..Just keep on touch to fix your TV and works fine again..
Regards,
Chester Pendilton.
Jan 18, 2012 | LG 32LG30 32 in. LCD HDTV
I turned on my tv this morning and it started smoking and of course smelling like something inside was burning. We took off the back and can see nothing that looks burnt or melted but the tv still wont...
hi,
may be ur tvs lamp side have some problem. may be the lamp over heated and burned. just open its lamp cover ann check it.
also check its power supply input point(near fuse) there is an MOV (used for voltage surge protection) is burned or not. if there is any voltage surge it will get shorted and the fuse will blow off, protect the power supply for any further damage. check the fuse also. if found open then check the MOV. insert fuse only after replacing the MOV.
ok
Dec 22, 2010 | Samsung HL-S5087W DLP TV
TV is completely dead. I checked fuse and it looks fine as shown by 120volt signal between fuse and ground. I suspect something wrong with remote unit. Does this remote come with 3 1.5v batteries or with...
Unfortunately this tv has received many bad reviews. One being the remote does not function properly while trying to turn the tv on/off. Other negative reviews have read the remote has a very short range. Can you turn the tv on by using the buttons found on top of the tv itself? The remote comes with 2 AAA batteries. When you said the tv is dead did any lights come on the front? If so check the power supply for any bulging capacitors. You may have several whose life span has come to an end and stopped charging enouugh to power on the back lights which lights the screen. This may be your problem. Good Luck!!!!!!!
Mar 08, 2010 | Protron PLTV-32 Television
Pioneer 50 inch projection tv won't turn on
I only fine 5 fuse where is the 6 fuse locate? Please help I found the 5 on the power board... is the 6 fuse somewhere else not with the power board?
Mar 15, 2009 | Pioneer SD-P50A3Q 50" Rear Projection...
HI I have a insignia model NS-32LCD tv and it stop working the only thing that would happen is the light on the bottom of the TV would change from blue to red. so I call the TV man and he look at it and...
This happend to me before with my LCD that I bought last year. It worked fine for a while and then, all of a sudden...nothing. The power supply was fine, fuses were fine BUT one of the chips or capacitor went bad on the process board and not being able to get the adiquate amount of power to be distibuted. I had my tv replaced and found out this was a defect rather than you or something done wrong to the tv.
Hope this helps you....
Jan 03, 2009 | Insignia IS-LCDTV32 32 in. Television
TV WONT TURN ON
I fixed it myself. I found that the t6.3 amp/250v fuse had blown. I bought the fuse at a television parts supplier for $2.00 put it in and it worked.Hooray! It has been working just fine now.
Nov 23, 2008 | Sony KV-36FS17 36" TV
Follow up on "no power to my tv"
3d picture ...sounds like to me a convergence amp issue...what type of tv is this?
Dec 01, 2007 | Televison & Video
Panasonic PT-47WX49 47" Rear Projection Television Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
