Question about Acer Aspire 5610 Notebook
Cd drive not working - Acer Aspire 5610 Notebook
  • frenchtbass2 Apr 29, 2010
    cd draw will not eject also
    Guru:
  • 163 Answers
May be the lens of the cd drive is damaged
Posted on Apr 29, 2010
I HAVE A PRODUCT KEY AND WANT TO DOWNLOAD IT TO THIS COMPUTER BUT THE DISC ISN'T WORKING
you need to do a lot of test, 1. check in bios if your cd-drive or dvd- drive is in enable if not enable it. 2. if your cd drive was enable, try to insert another cd, if the cd you insert was read by cd- drive, the problem is your cd. then if the other cd you insert is also din't work the problem is the cd-drive or dvd- drive. :P
Aug 25, 2011 | Microsoft Office Professional 2007 Full...
Hi I have cf-19 I need to install mapping software that requires a resident cd drive to install. Will any usb cd/dvd drive work?
As long as it is a plug&play drive it should work just fine. It's hard to install a USB CD/DVD Drive that isn't plug&play.
May 02, 2011 | Panasonic CD FOR TOUGHBOOK (cf-vcd721w)...
Cd rom driver
in most cases your CD-Rom drive won't need any external driver, because they are embedded in the OS. In case you are experiencing problem with your optical drive, just try to remove and then reinstall it from windows' hardware managment software.
Hope it helped,
Franz
Mar 02, 2011 | Computers & Internet
Blank cd's are not recognized by the Dell Inspiron cd burner
I would first try removing the device in the control panel, system, device manager and then reinstalling the driver. There may be a problem caused by a windows update. In general CD drives rarely go bad. If the CD works say for a music CD then it should work for blank cd. You may also want to check the CD type. If you accidentally used a DVD, that won't work and in some of the older CD drives, they may not handle every type of CD format.
Good Luck
Feb 02, 2010 | Dell Computers & Internet
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
Cd/dvd dosen work pleace geimy a solution
i cant get you. cd/dvd is not working or cd/dvd rom drive is not working ? To work cd/dvd rom drive properly, Make sure the Jumper settings of the drive is set to slave or else remove all the jumpers from the cd/dvd rom drive, it automatically sets to slave. Check the power cable and the FRC(flat ribbon cable) of the cd/dvd rom drive. Hopefully it should work. Thank you.
Sep 11, 2008 | Computers & Internet
Dvd playr
Just the whole DVD/CD Drive isn't there, there is a CD Drive on my laptop but it just does not work, doesn't read anything nor does anything work.
In My Computer, there is no icon for the CD Drive.
Aug 11, 2008 | Acer Aspire 3680 Laptop
Drive cd dirve not working
This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
Click Troubleshooter to start the troubleshooter for this device.
Jan 23, 2008 | Computers & Internet
Boot error, won't even boot with xp cd
hi.
you might wanna check if your XP is a dvd or cd. if it is a dvd your cd drive can not read dvd cd's. if it is a cd than your cd/dvd drive is not working. another thing you can do is to take out your cd/dvd drive and plug it back in. to see if it works. if the drive is working, you can try a different XP CD to see if it is working. if it is still doing the same thing. you might wanna check your hard drive to see if it works.
hope that helps.
thanks.
Dec 27, 2007 | Toshiba TE2100 Notebook
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Acer Aspire 5610 Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
