Question about Zebra S4M Thermal Label Printer
RIBBON IN I can not use the printer I check all sensors and the problem is still there RIBBON IN ???? Please I wil need an urgent solution. We are using this printer in different countries that is the IT department recomendation. So this solution will be usefull for us. Thanks Best regards Fouad ZORGATI
    Scholar:
  • 97 Answers
The RIBBON IN message means that the printer is set for Direct Thermal printing. Check your printer driver - Each driver is a little different but there should be a setting for choosing between Thermal Transfer and Direct Thermal printing.
Once set to Thermal Transfer, the error will go away.
Hope that helps !
Posted on Apr 29, 2010
Warning ribbon in
the ribbon sensor it activated, change settings from lcd panel to Direct thernal, and check if settings from driver are correct, Thermal Transfere if using ribbon, Direct thermal if doesn't use ribbon, ru calibration if needed, or if doesnt work, you can do the manual calibration and/or reser to factory default. Hope it helps. Paulo.
May 16, 2014 | Zebra S4M Thermal Label Printer
P330i gives out of ribbon error. When completing command "!SA" it ran the blank card through the printer into the other side. After right after that the printer flashed the "out of...
The printer uses three sensors in relation to the ribbon. The RFID (chip on ribbon). When you go into the printing preferences for the printer it should detect any color ribbon, and say ribbon type changed to (ribbon type). If so both the ribbon and RFID sensor are working properly. Then there is the color ribbon sensor, which has the blue and amber LED's, and is used to detect the panel of the ribbon. Thirdly the flag sensor which is on the back end of the supply reel, to detect the ribbon turning. . Additionally, CALIB command has never worked for me. !SA is an auto self adjustment for multiple sensors. additional you can use !CSA 0 without ribbon in machine, then run !CSA 1 with a ribbon (color ribbon is a must with any calibrations). You can also run !SAP 0 for card sensors !SAP3 for mag encoder card sensor. !SAP 1 for ribbon calibrations. if all else fails, you can manually set the ribbon by using !CSA 5 70 120. Please remember these commands are for genuine zebra I Series printers, and that they are case sensitive, and spaces are present. If none of the above corrects the issue you may need to replace one of the three sensors, the daughter board, or possibly the main logic board.
Sep 20, 2011 | Zebra P330i Thermal Card Printer
Good morning. my printer will not calibrate. Could you please help me out?
Perform a Manual Calibration:
Perform a media and ribbon sensor calibration to reset the sensitivity of the sensors so the
media and ribbon are detected more accurately. If you change the type of ribbon or media,
your printer may operate better if you perform this calibration.
Calibrate Media and Ribbon Sensors
Use this procedure to adjust the sensitivity of the printer's sensors. In a
printer that has the Thermal Transfer option installed, both media and
ribbon sensors are adjusted. In a Direct Thermal printer (no Thermal
Transfer option installed), only media sensors are adjusted, and the LCD
displays for ribbon do not appear in this procedure.
Important • This procedure must be followed exactly as presented.
All of the steps must be performed even if only one of the sensors
requires adjustment. You may press the left arrow at any step in this
procedure to cancel the procedure.
How to select this parameter:
1. Press ENTER to start the calibration procedure.
The LOAD BACKING/REMOVE RIBBON prompt displays.
2. Open the printhead.
3. Remove approximately 8 in. (203 mm) of labels from the backing,
and pull the media into the printer so that only the backing is between
the media sensors.
4. Remove the ribbon (if used).
5. Close the printhead.
6. Press ENTER.
The message CALIBRATING PLEASE WAIT displays.
The printer adjusts the scale (gain) of the signals that it receives from
the media and ribbon sensors. On the sensor profile, this essentially
corresponds to moving the peak of the graph up or down to optimize
the readings for your application.
RELOAD ALL displays.
7. Open the printhead and pull the media forward until a label is
positioned under the media sensor.
8. Reload the media and ribbon (if used).
9. Close the printhead.
10. Press ENTER.
The printer does a calibration; during this process, the printer
determines the label length. To see the new readings on the new scale,
print a sensor profile.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 25, 2011 | Zebra Z4Mplus Label Printer
Hi There. I have Tally T2265 Serial Matrix Printer. It shows "Hardware Alarm & Check Ribbon Error" after printing 2 or 3 pages. Sometime it prints 7-8 pages and sometime it prints 2-3lines...
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Before suspecting other components check the printer model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribbon should be 062471.
If the correct ribbon is used the problem could be the timing strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be caused by the timing station on the carriage, the carriage motor.
Mar 10, 2011 | TallyGenicom 2280 Matrix Printer
Z110xilll after 3or4 labels paper out error
Please run manual calibration
(take 2 or 3 labels and load the labels under the printhead and sensors, close printhead, press enter,
if ask for "take the ribbon," just open the print head, take the ribbon out from the sensors, close printhead, enter.
then if ask for load media, just put everything like you normaly setup the printer and press enter. The printer gona run the calibratio, Please close the door case, this can afect the sensors data.
save
tur off the printer and back on again.
run sensor profine. check if sensor check the gap (smal mountan )
Nov 12, 2010 | Zebra 110Xi III Plus Thermal Printer
I have a Sony UP-DR150 digital photoprinter that displays "Check Ribbon" I have tried changing both ribbon and paper at the same time but still keep getting same message, any ideas?
Have you tried to Replace the Ribbon and Paper? Make sure the Ribbon must be Compatible and of Appropriate Size. It should not be loose. This message would Appear until Door is Open. Once you Replace the Ribbon and close the door, the message would disappear.
If not, Unplug the Printer for Few Minutes, say 15 minutes and then Turn it ON. That would Reset it.
Note - There was an Upgrade that was done for the software. If you have not Upgraded the software, this message would be there. Upgrade the Software and the message would disappear.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 23, 2010 | Office Equipment & Supplies
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
S4M .how to do when it show alert massage
Are you using a ribbon? If so, then the ribbon is not loaded correctly passed the ribbon sensor. Or, the media is loaded in this position. Check the diagram on the inside of the door to make sure labels and ribbon are installed correctly. If you are not using ribbon, then you need to set the printer to direct thermal in the front panel and/or the software.
Oct 13, 2009 | Zebra S4M Thermal Label Printer
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
"check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Jan 24, 2009 | TallyGenicom 2280 Matrix Printer
Zebra S4M Thermal Label Printer Logo
638 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
