Question about Hotpoint RGB745 Gas Kitchen Range
Hello the bottom of my stove doesn t light i
Hello the bottom of my stove doesn t light i can use the "broil" fonction but the bottom isn t working
  • Hotpoint Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 04, 2010
I connected a dvd player and a vhs player but I have only one in fonction, I can't have both 2
make sure the connectors to the one that isn't working is in the right place and secure.
Oct 01, 2012 | LG 42PG20 42 in. Plasma HDTV
Oven will not heat up
when you ask a question you should send the brand name and model number off of the machine you need help with.if it's gas check the ignitor,if you can see the orange glow from the ignitor as soon as you see it start to glow if the flame doesn't ignite within 40 seconds the ignitor is bad.if you can't see it remove the racks and the bottom floor of the stove so you can see it,if it doesn't glow check the ignitor for continuity to see if it's bad.if the broil works and the bake doesn't 90 percent of the time it will be the ignitor.if it's electric send more info.
Jan 05, 2012 | Kitchen Ranges
Kenmore stove not heating up anymore.
if no broil or bake work, check the thermal fuses in back. some are resetable
Feb 09, 2010 | Kitchen Ranges
Bottom filament on bake not working but broil and
FAULTY ELEMENT OR THERMAL SWITCH. HAVE IT CHECKED OUT BY AN ELECTRICIAN.
Sep 07, 2009 | Stoves 720EF Electric Double Oven
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Replacing Igniter on Hotpoint RGB528PEAWW Gas Kitchen Range
you should have a broil glow coil at tol and one on bottom. to access the bottom, open the door and look to the back on the oven floor. ther should be a srew one on each side remove and lift bottom up. you should be looking at the glow coil. i would also remove the pan drawer for access.it would be abnormal for bth the broil and bake to fail at the same time. if this is the case i would confirm power is leaving control to the selected glow bar. they shoul pull about 3.2 amps. then i would focus on the valve. which is opened by the amp draw of the bar. one wire on the valve is common and the other feeds from the control through the valve to the glow bar
May 18, 2009 | Hotpoint RGB528PEAWW Gas Kitchen Range
Old Eaton Viking Stove - broil won't turn off.
I have the same stove, and just had the same problem. I looked all over the internet to try to find an answer, and then went back to my stove to check the serial number and where the fuses are was the instructions printed on the stove itself.
SO HERE'S THE SOLUTION
1. The timer start knob (the one with little running guy picture) must NOT be pushed in. If it is, turn it slowly until it snaps out.
2. The timer stop knob (the one with the picture of the stop sign) must be completely pushed in.
I hope that helps everyone out!
Dec 21, 2008 | Viking Stove/Oven/Range Timer Knob -...
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
very likely your oven control it does those things without any input from the oven so if it doesnt do what it is supposed to it is likely bad
Aug 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Hotpoint RGB745 Gas Kitchen Range Logo
349 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
