Question about Whirlpool LER4634J Electric Dryer
Some times the heater works and some times it doesn't.
    Habit-Forming:
  • 98 Answers
You most likely have a bad heater. Sometimes the broken heating element will make contact until the machine vibrations disturb it. A faulty thermostat could also cause this symptom.
Try to check for the problem when the heater is not working.
Unplug the machine! Check the heater for continuity with a multimeter. If it does not have continuity, replace it. If it does have continuity, I recommend that you also remove the heater and carefully look to see if the heater coil is broken, but touching at the break.
If the heater is good, the operating thermostat may be turning the heater off too soon.
Other failures can also keep the heater from working: temperature switch, timer, centrifugal switch, etc.
Posted on Apr 29, 2010
98 gmc heater doesn't work all the time
if your heater fan blows all the time when you turn the switch on, then check the heater control valve under the hood right before the heater core. its inline with your heater hoses going into the heater core. the valve opens one way and closes the other way as you turn the switch from hot to cold.
Apr 14, 2013 | 1998 Ford Taurus
Blower for the heater doesn't work
most likely you had a bad resitor they go bad on gm all the time also check your fuses frist
Dec 01, 2012 | 2002 Buick LeSabre
The heater doesn't work
your heater doesn't work any more
Apr 23, 2012 | 1994 Opel Astra
I have a Dyna-Glo heater, model #RMC-FA50A, heater will not get hot and there is a odar and eye burning smell after running a short time.
When this type of problem happens, you most likely need to take apart your heater and clean it well. If it still doesn't work after that, blow it out with an air compressor. If then it still isn't working, I suggest you sell that heater and buy a new one.
Dec 17, 2011 | Dyna-Glo Heating & Cooling
I have a Bosch Tankless Water HEater Model GWH 2700 ES NG with an error code of A3. I was told to push reset and the problem would be resolved. This worked several times and now it doesn't work. ...
Yes. Contact Bosch.
Error codes are considered start-point for troubleshoot.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Tankless are complex electronic machines.
If on-site plumbers cannot figure out problem, then you need trained service technician with a service manual for your specific product, who can ohm-test the electronics.
Bosch will have a list of trained service technicians. And maybe Bosch has another step for fixing problem yourself.
Fix most tankless problems yourself, same day, for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 14, 2011 | Bosch AquaStar 2400ES-NG
Hi, I have a Rinnai 406TR convector gas heater. It is working fine but I am now unable to change the temp setting. When I press the up and down arrows it just changes the time. I have checked the manual...
un plug from wall for 30 secs then plug in try to set clock and check mode then set temp req
if this does not work you may need to replace the thermostat control
Jun 10, 2011 | Heating & Cooling
Heater fan doesn,t work
if you are getting power at the fan plug, it is possible that the recycled motor is bad.
Feb 04, 2009 | 1994 Cadillac DeVille
Heater blows out cold air half the time
the heater doesn,t work blows cold air
Nov 20, 2008 | 2001 Ford Taurus
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
