Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
STUPID ME ! re Sharp TV
I have the same problem....it started when our tv was only about 6 months old but rarely turned off during a program and I thought I lost my digital signal. Circuit city told me it was cable problem not a product problem.
I changed some cables to new ones, the others were also new.
I don't think its temp related because mine does this when you first turn it
on. And sometimes now you can try dozens of times before you MIGHT
get the tv to power on to get a picture.
Otherwise my problems are same as the others who commented. I am going to check for recalls and hopefully I don't have to fight with them to get results. At this expense it is OUTRAGEOUS.....my Sanyo old fashioned tv that cost me 279.00 at Sams about 15 years ago is still ticking !!!
Any idea what the problem is before I go further?
  • jedikn1te May 11, 2010
    What exactly is the problem with the TV?
I need the code for an RCA remote model RCR311W for a sharp tv
Hello
Codes for Sharp TV with RCA RCR311w are
Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Direct code entry method
1. Manually turn on the component
you want the remote to control.
2. Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4. While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5. After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
6. To confirm that the component key
is programmed with the correct
code for maximum functionality,
test the component. Attempt to
control a variety of the
component's functions with the
remote. If some of the features of
your components do not work, try
programming the remote with a
different code in the list until you
find the code that allows the
remote to control the majority of
your component's functions.
Different codes can provide
different levels of functionality
OK
Mar 04, 2011 | Televison & Video
My 42 inch Sharp 1080p will not power up. It's only 6 months old, and a month ago it just powered off, and won't turn back on. Any suggestions...I thought maybe my grand children did something with the...
Check the power source?Try unplug,replug tv an hour later.Let the tv resetting itself back to factory setting.The tv should work now.No,LCD tv have common problems power supply board died alot.This tv is new,call Sharp for warrenty repair.
Sep 09, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV won't turn on...
the first thing to check is the power supply, and if the power supply is good the next possible damaged part is the inverter which is responsible for turning on the screen, this happens a lot. and of course if you don't have repairs skills don't mess with it. call the repairman. good luck
Jul 19, 2009 | Sylvania LC420SS8 LCD TV
T.V. turning on
yes my 26" sharp aquous LCD does the same thing, turns itself off and on at random times without explanation. I sent to authorized service center they replaced the power supply under warranty then it failed within 6 months and neither the repair center nor sharp will do anything about it other than sell me a new powersupply for $425.00. I have contacted a power supply repair center in Texas who has vowed to fix it once and for all. We'll see in the next week if they fix it or not.
Oct 30, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My Sharp Aquos
Burnt out pixel line. Usually the panel needs replacing
Jul 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound on Sharp Aquos 37' LC-37D4U
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
Sharp LCD HDTV Facedown Damaged
not sure i laid over a lcd for a couple mintues. that belong to my comapny, once i stood it back up the screen was cracked. i like to have fell over, the replacement part is 12266.00 i guess your out of luck. as i am.
Oct 13, 2007 | Sharp Aquos LC-37HV6U 37 in. HD-Ready LCD...
Rca truflat with green tinted picture?
Just because a machine has failed, there is no cause for you to call it a stupid TV. And as it is only 6 months old, why not take it to the Company service Centre? There must be warranty.
Apr 01, 2007 | RCA 27F530T 27" TV
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
261 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
