N Power 15 inch LCD Spongebob T.V. screen goes black after 10 minutes or so repeatedly. Sound but no picture. Turn it on and off to get picture and repeats itself.
  • 19,396 Answers
Hi.
This problem is usually caused by a faulty inverter. In some occasion a faulty power board not supplying proper voltage to the inverter, or a faulty controller board can cause the problem.
Usually the problem is the inverter.
If the power adapter is external, then there is only one voltage, in that case the power adapter is tested reading volts at the DC connector. Voltage must differ of no more of .5 Volts from value stated on specs.
If the power cord connects AC directly to the TV, then there is an internal PSU with different voltages. One of the higher DC lines goes to inverter, this must be tested.
Here how to test parts in case the TV uses an interna power supply:How to test an LCD TV or monitor PSU and Inverter.
Testing and repair must be done by a technician.
To get parts, or to get a quote on repair call the number listed on the owners manual. If you have misplaced the manual, look for the Imation or Memorex (they are same company) support number in your area. Here the US contact.
Please do not forget to leave feedback. That is important for us.
Regards.
Posted on Apr 29, 2010
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Jul 05, 2010 | Polaroid FLM-3232 Television
My tv has sound but the screen is black. At times
Ur LCD inverter board is dead.Must replaced the board.Usally a long board.
Jan 05, 2010 | Olevia LT27HVX 27 in. LCD Television
No picture, no sound, green light flicker ongoing
The power supply in the Tv has failed and should be looked at by a qualified technician.
Sep 09, 2009 | Samsung Televison & Video
My screens works for about 10 or 15 minutes and then goes out...
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 03, 2009 | HP Pavilion dv2715nr Notebook
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Gateway shd 3010 LCD goes black
I have the same problem now!!! Did you ever find a solution?
Jan 02, 2009 | Gateway SHD-3010 30 in. HD-Ready LCD...
Picture disappears and changes to white screen
I am assuming that this is the nature of the fault and that it is repeatable. Does what you have described occurs every time you turn the damn thing on. You haven't said is whether or not there are changes in sound when the screen malfunctions or whether your unit plugs into a GPO or a black box which plugs into the GPO.However this only dictates the ease with which the faulty component is replaced What seems to be happening is that white level controls are setting to maximum gain. If the control is digital It is almost certainly due to dirty power. The sound level should also change if the power supply is the culprit. Spikes cause the gain on the control to ramp up or down erratically (change) on digital parameter controls. This resulting in bleeding for white levels and a change in the sound levels. Replace the power supply if possible. A cheap workaround can be made if my assumptions are correct and the main transformer is not faulty. Leave a post if you want more info
Aug 01, 2007 | TruTech PLV1615T 15 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
