Have lexmark 1200 series will not feed paper i
Have lexmark 1200 series will not feed paper i checked to see if something was jammed noticed roller on right has no tension don't know if it is suppose to the printer just stopped feeding in the middle of print job
    Scholar:
  • 118 Answers
turn on/off, unplug, plug inhave lexmark 1200 series  will not feed paper i - 2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck preventing from accepting paper. although you did this, there might be a small particle hanging you up. I have experienced this before. see if both sides have cogs that catch the roller, one might be offset?
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Posted on Apr 29, 2010
Hello the paper feed roller is not pulling the paper down evenly. It appears that the bar on the left paper feed wheel is out of line. how can i access the rollers to rectify this
This article in the Lexmark website on How to Remove and/or Avoid a Paper Jam in your Lexmark X5300 & X5400 & X5600 Series All-In-One might help resolve the problem. However, if the paper feed roller is visibly "out of line" causing it to mechanically fail, I would strongly suggest you contact Lexmark technical support for assistance.
Apr 18, 2011 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x6170 paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
May 01, 2009 | Lexmark X6170 All-In-One InkJet Printer
How do I clear carrier jam on lexmark p6250
Oct 25, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark X2250 uneven paper feed
Oct 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X5470 printer says, "Clear paper jam, then press check mark."
May 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X4850 paper jam
May 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X2470 Jam
IF this did mot work ,Please contact Lexmark as they sent you refurbished printer which may defective roller on it , ask them to send a good printer this time..............
Mar 22, 2008 | Lexmark X2470 All-In-One InkJet Printer
LEXMARK PRINTER DOES NOT WORK JAMS PAPER
Nov 29, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Paper will not feed
Check for a jam again somewhere in printer unit, rollers, teeth, down back in paper feeder area. I thought i had no jam in my unit either until i got a torch and found the tiniest slip of a shred barely noticeable right in the middle of the teeth/roller. Remeber to turn it off after this, to reset it.
Aug 16, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
125 people viewed this question
jasbo
jasbo
