Question about Castelle Faxpress (66298601294) Server
Unable to communicate with the server - my Lan led is orange
My Castelle fax is unable to communicate with the server. I changed my network cable, I changed the port on the switch, the Lan led still orange and the led alert is red. I'm able to ping the IP address on the network.
This is the message that I get
CPI Error No. : -2221
CPI Error : Network communication error (Client timeout). FaxPress client is unable to communicate with the server. If this problem persists, please notify your system administrator.
File : D:\faxpress6.3\Faxpress\Client\Faxmain\Source\Server.cpp
Line No. : 561
HP Proliant server 350 halts with LED 2 and 3 Orange
Open the case. Power up and look for internal LED that corresponds with warning light number 2 on main board.
Number 3 is power.
Dec 05, 2012 | HP Compaq ProLiant ML350 G3 Server
Proxy setting 130
Exactly error: "Unable to connect to the proxy server
A proxy server is a server that acts as an intermediary between your computer and other servers. Right now, your system is configured to use a proxy, but Google Chrome can't connect to it.
Here are some suggestions:
If you use a proxy server, check your proxy settings or check with your network administrator to make sure the proxy server is working.
If you don't believe you should be using a proxy server, try the following steps: Go to Wrench menu > Options > Under the Hood > Change proxy settings > LAN Settings and deselect "Use a proxy server for your LAN."
Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed."
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
Sep 19, 2011 | Google Chrome
I am able to connect 80.0.75.60 server remotely ..in that i need to connect to one of my application server 80.0.75.62. i am unable to connect. actually servers are in sum other place. while pinging to...
The gateway at the remote end may be down. Ensure that the remote gateway runs fine. See whether the application server (80.0.75.62) has communication with remote gateway.
Sep 27, 2010 | D-Link DFL-800 Firewall
I have Dell V505w wireless printer. It has worked fineuntil I replace my router with a new one. Now I can't scan anything to my computer. The orange light on printer blinks, indicating the printer is...
Either set the new router to the old router's IP, SSID, channel, key, etc. Or set the print server to the new router's network, SSID, channel, key, etc.
Feb 05, 2010 | Dell Computers & Internet
Faxpress sent faxes vanish
Immediately after posting, received SPAM from this site. Was offered some type of professional "elite" help. New is: I AM AN ELITE PROFESSIONAL. This is a gimmick site that harvests information and harasses you to buy something.
Jun 06, 2009 | Castelle FaxPress 2500 Fax Server
Sharp MX-M350N Error CE-03--We changed ISP providers and can't get Inbound routing to an email working again. I changed smtp server in "Network Setup". The "Connection Test" passes for SMTP. We can email...
CE-03 is a communication error, obviously. Your print card and your new SMTP are not talking together. Your system is probably OK at this point, but is unable to communicate well with the new network system. Work with an IT department to resolve this.
Jun 02, 2009 | Sharp AR-M450N Copier
Red alert ligth won't go out
Did you check your printer queue tab. When I was having trouble getting receipts to print the print request would go to the Printer Queue and upon opening the tab I saw my print jobs being held there. Once I deleted them the Red Light went out. Check out your user manual as I believe there is a section that tells you how to troubleshoot the lights...as some issue relate to flashing lights and other relate to solid lights. Hope this helps
Apr 10, 2009 | Castelle FaxPress 2500 Fax Server
Can I create a closed hub lan using MS Server 2003 and a client?
try going into my network places and on the left pane go to set up ahome or office network make sure you do this on each computer and the workgroup name must all be the same on each computer you want to be in that network.
Nov 19, 2008 | Computers & Internet
Idle Fax Lines
reconfigure your fax machine redesignate again to the lines in seperation.
Apr 02, 2007 | Castelle FAXPRESS PREMIER ALOG-16-LINE...
Castelle Faxpress (66298601294) Server Logo
590 people viewed this question
Top Castelle Computers & Internet Experts
David Payne
David Payne
Are you a Castelle Computer and Internet Expert? Answer questions, earn points and help others
