Question about Car Audio & Video
How do i repair the petrol gauge needle on my saab 9-3, it wont settle down, one minute it shows an orange light , then it will show half or a full tank, then it will show an empty tank,
  • Kara Davies Apr 29, 2010
    thanks, i will keep you posted with how i get on.
    Guru:
  • 332 Answers
Is shows a problem with fuel level sensor located inside the fuel tank, these sensors are generally attached to the fuel pump, sometimes impurities in fuel can cause a temporary or permanent failure of those sensors. What you can do is open the fuel pump and have a look at the sensor, clean up any visible residues and install again if you still have the problem then you might need to change that part. Have a look at it and let me know if you need more advice. Best
Posted on Apr 29, 2010
Problem with my petrol float
Yes it sounds like you have found your own problem the float in your petrol tank is faulty and needs to be checked out. Check the wiring to the gauge is ok before doing anything at the end where the wires connect to it.
Jan 19, 2016 | Cars & Trucks
Petrol float
press helpful button,Order one from link below
RockAuto Parts Catalog
Jan 12, 2016 | Cars & Trucks
Gas tank will not fill up on 2001 ford expedition
Gas as in gasoline or gas as in LPG gas? If its petrol, the fuel sender may be out of adjustment. (Usually means a new sender) If its LPG, the fuel stations are set to automatically shut off at 80% full. The gas tank will never actually be full to the brim but the gauge should be showing full if the gas nozzle keeps shutting off. Have a look on the LPG tank itself, they have a little gauge on them which shows how full it is. I have 2 tanks on my car , when "full" or when the pump shuts down, the tank gauges show just under full but the gauge on the cars dash shows full (2005 BA Ford)
Feb 18, 2015 | Ford Expedition Cars & Trucks
Why is petrol gauge showing fuel when nearly empty
if I had to guess then you have a bad float in the tank
Jul 11, 2014 | Light Outboard Motor Boat Bass Fishing...
Fuel gage showing half a tank but trip computer only registering 60 miles left
Its very simple. If the gauge is showing half full then fill the tank and see how much fuel it takes. If the amount you add is approximately 50 percent of the fuel tank capacity then you know the fuel gauge is accurate . In that case the computer is giving an inaccurate reading and should be ignored. All you need is an accurate fuel gauge - it does not matter a row of beans what the computer says if the fuel gauge is reading correctly.
Dec 22, 2012 | Saab Cars & Trucks
Fule gauge dose not work right
Does it stick at about half full? I would fill up, the gauge would show full then after 60-70 mile when gauge should show less than half to a 1/4 tank the gauge still showed 1/2 tank so I'd go ahead and fill it up. Finally, I watched my mileage and when my yellow low on gas light came on I filled it half full. After a couple of weeks I filled it up and the gauge has worked every since.
Apr 08, 2011 | 1985 Ford Bronco II
Hullo, I drive a 5 door 1.3ltr manual Ford Festiva. When the petrol tank is full the petrol reads full. When the petrol gauge reads around half full the petol gauge falls to zero. The petrol gauge will...
Your problem is the fuel gauge sending unit. It needs to be replaced. Another benefit of owning the durable festiva is the access panel under the back seat. You don't have to drop the tank to fix this problem.
Feb 12, 2011 | Ford Festiva Cars & Trucks
89 jeep Grand Wagoneer fuel gauge not reading.
Did the mechanic use an OEM replacement unit or an after-market unit? I think the original unit has a damping circuit to prevent immediate response when accelerating/stopping/cornering; the needle reacts slowly to changes in fuel level. If the new unit shows an immediate transient response, but settles back down to the actual fuel level, I'd just live with it.
May 18, 2010 | 1989 Jeep Grand Wagoneer
2004 saab 9-3, gas guage shows empty, tanks is full. Fuse?
this problem is caused by a defective gas gauge sending unit, it is located inside the gas tank, u must remove the gas tank to replace the part
Jan 19, 2010 | 2004 Saab 9-3
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
